Old 03-28-2016, 08:18 PM   #1
Frankie Z's Avatar
Pex diameter
I want to purchase pex tubing in case I develop a leak while camping.
I have a 2650S sunseeker. What size diameter pex do I need and what tools and fittings are recommended to have in case of leaks.
Frankie Z is offline   Reply With Quote
Old 03-28-2016, 08:25 PM   #2
Ford Idaho's Avatar
Likely 1/2 inch.
Shark bite type.
for those all you need is this.
http://www.googleadservices.com/page...nshoo_clickid_
Old 03-28-2016, 09:27 PM   #3
WFD
The Sharkbites are a bit pricey but they sure work nice, easy to install, especially if you have to do a repair in some tight, hard to reach, body contorting spot as is often the case with RV plumbing. In a lot of the spaces you will be hard pressed to get in there with a pex ring crimping tool, so the Sharkbites are awesome. Easy to find in most major hardware stores.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 03-29-2016, 05:00 AM   #4
grumpy0374's Avatar
I also carry several sharkbite assorted fittings and half dozen 3 ft lengths of pex for emergencies. All the lines in our Lexi that I've been able to access are 1/2 inch, so I imagine your rig is the same.
Assortment of O rings, roll of teflon tape, some rubber O-type rings for fresh water hose are also good to carry
Also, get a small tubing cutter, one of the small type thats easy to get into small areas. Invalueable little tool, and necessary to get a clean edge end when working with pex.
Grumpy
Steve & Cheryl + Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
grumpy0374 is offline   Reply With Quote
