Old 01-11-2013, 08:26 PM   #1
Plastic Traveling Slide Poles
We got our 2860 last weekend and was wondering if anyone ever uses the plastis poles to keep their slides from sliding out. We drove from Des Moines to Colorado Spings with no problems. I tried to insert a couple in the couch slide and there is nothing to hold them in place.
Wildkats66 is offline   Reply With Quote
Old 01-11-2013, 08:37 PM   #2
William
WEMig's Avatar
I used to use the slide stops on an older manual slide. I believe with today's rv's it isn't necessary. I would definately check your owners manual.
2012 Crusader 320RLT
2011 F250 Lariat 6.7L
2016 (19 Nights Camped/1348 Miles)
2015 (38 Nights Camped/3560 Miles)
2014 (28 Nights Camped/1980 Miles)
2013 (30 Nights Camped/1411 Miles)
WEMig is offline   Reply With Quote
Old 01-11-2013, 10:35 PM   #3
Never used them and had no problems. If you do, hang ribbons from them so you don't forget and try to open the slide with them installed.
ATVer is offline   Reply With Quote
Old 01-12-2013, 02:23 AM   #4
GM
bclemens's Avatar
Mainly there for old hydraulic slides. If there was a leak, the slide could creep out. Rack and Pinion...its not going anywhere without juice.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
Old 01-12-2013, 07:19 AM   #5
Herk7769's Avatar
I did not know they were plastic in a Sunseeker. In my Flagstaff 5th wheel I would not move mine at highways speeds without them installed in my main slides. They are Lippert rack and pinion.
This subject was covered at length in several threads. There are advocates for "useful for hanging clothes" and I would never move the camper without them installed"; I am in the latter camp.
Here are some previous threads where the topic is discussed "pros" and cons."
This one has over 100 posts
Slide-out cheater bar bolts
Slide out
Slide Lock bars
slide secure bar
what happens when slide lock turned the wrong way
HAM CALLSIGN - KC3FFW
Old 01-12-2013, 07:25 AM   #6
Herk7769's Avatar
Here are some photos of a properly installed slide lock.
Name:	Roof Shots and others 025.jpg
ID:	22895   Click image for larger version
Name:	Camper Slide Braces 001.jpg
ID:	22896   Click image for larger version
Name:	Camper Slide Braces 002.jpg
ID:	22897   Click image for larger version
Name:	Camper Slide Braces 003.jpg
ID:	22898   Click image for larger version
Name:	Camper Slide Braces 005.jpg
Old 01-12-2013, 09:04 PM   #7
Plain Old Member
Never used them. The most I've had a slide creep is 1 inch, and that was a schwintek.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 01-12-2013, 09:29 PM   #8
when i got my travel trailer the dealer told me never to use them and just throw them away they said they had more damage from people using them then not
jkklops is offline   Reply With Quote
Old 01-12-2013, 09:50 PM   #9
The slidlocks in my 2006 were metal bars and a the did was pop out of place and damage the cabinets, this told me that a design change was needed, I stop using them for the slideout and started using them to support my work table in the garage..........
Old 01-12-2013, 09:55 PM   #10
Now that I think about it, my new camper didn't even come with slidelocks and I have three of them but I must say that the design is somewhat different.
