02-22-2015, 02:15 PM
Senior Members
Play DVD on Jensen TV in kitchen
I am trying to get the DVD I am playing on the Jensen radio system in the cab to show the picture on my Jensen TV in the kitchen of my 2015 3010DS (the brake is also set on the chassis). I have all the cables (white red yellow) on the TV connected and I have read all the blogs but to no avail I still cannot get the picture to show on my TV in the kitchen. Hopefully someone has experienced this same problem and has a solution.
02-22-2015, 02:50 PM
Ret E-9 Anchor-clanker
Have you gone through the "menu" on the TV in the kitchen and tried all inputs one by one?
02-22-2015, 04:15 PM
Senior Members
Yes, (AV, COMP, HDM1, HDM2, USB).
2015 3010DS Sunseeker
2010 Jeep Wrangler Unlimited
02-22-2015, 09:06 PM
Our's comes up on AV2 on the TV set; using the "source button".
02-23-2015, 12:00 AM
Make sure in your cabinet next to the TV that the AV control box is on the right setting. It is a push button box that allows you to control what signals go to what tv's in the unit. For example I can be watching what's playing on the dash tv unit on our living room tv, bunk bed TV and master bed room TV.
2014 Sunseeker 3170ds
Global Wedding Photographer
02-23-2015, 09:01 AM
Are you running separate cabling to the external component connections on the rear of the TV? If not, that would be my next choice. Good hunting.
02-23-2015, 12:09 PM
Commercial Member
So with the E-brake set does the DVD play on the Jensen radio screen?
Alos see attached.
02-23-2015, 02:09 PM
Senior Members
Yes, it plays on the radio screen.
02-23-2015, 02:16 PM
Commercial Member
OK, make sure you follow the instructions to make the the "Rear TFT" is set for Disk.
Then make sure the TV is on Av1 or Av2. If neither of those work it would be they are wired to the wrong spots (TV or head unit) or a bad connection.
02-24-2015, 10:53 AM
Senior Members
Thanks Mr. Clemens the dvd is now playing on the TV in the kitchen!!!!!!
