Old 10-20-2018, 07:32 AM   #1
Power antenna switch for bedroom TV
I see it on the Living Room TV and I get channels on that one but I don't see one for the 12V TV in the Bedroom where I don't get any channels. I hooked up the cable underneath the 12V socket to the TV but nothing comes in.
Any suggestions?
2014 Sunseeker 3010DS on Ford Econoline E450 Chassis
Newly Retired!!!!
Atlanta Panther is offline   Reply With Quote
Old 10-20-2018, 07:36 AM   #2
Dcbenny's Avatar
Any suggestions?
Just a question did you switch BR TV to cable and do I channel search.
Don & Liz B.
Pink Retired Greyhound
2016 GTS 2800QSF
Dcbenny is offline   Reply With Quote
Old 10-20-2018, 07:37 AM   #3
A32Deuce's Avatar
The switch in the living room controls your whole unit. If you have over the air or catv on the or tv then you should have the same on the be tv. You have to do a search on each tv and choose a source and channel search. Many miss doing the search on each tv.
A32Deuce is offline   Reply With Quote
Old 10-20-2018, 12:12 PM   #4
I scanned for antenna should I put it on cable since it gets its feed from the LR TV?
Newly Retired!!!!
Old 10-20-2018, 01:36 PM   #5
Dcbenny's Avatar
If you are trying to whatch cable tv put tv on cable and scan for channels if you want to whatch over the air channels put tv on antenna and scan for channels. For cable tv booster needs to be off press button no light for over the air booster needs to be on press button for light on
Don & Liz B.
2016 GTS 2800QSF
Old 10-20-2018, 09:04 PM   #6
Got it Fixed!
I think what happened was that I put the LR TV on antenna and found channels but on the BR TV the previous owner had it on cable and I had not changed it like I had thought.
Thanks for all the help!
Newly Retired!!!!
antenna, bed, power, roo, switch
