Old 10-31-2014, 09:50 AM   #1
Mike & Molly's Avatar
Power For Awning
Extended my awning today, and was surprised to find the main battery cut off for the coach was in the off position.
(stairwell switch)
Is this the way it's designed to work, or do I have a wiring problem?
Thanks for any help.
2013 Sunseeker 3010DS
Mike & Molly is offline   Reply With Quote
Old 10-31-2014, 10:06 AM   #2
bubbles's Avatar
Normal operation. Awning fused directly off of battery
Old 10-31-2014, 01:37 PM   #3
Scootdawg's Avatar
If the awning fails to extend, remove the electrical panel (by steps on 2900) and replace the 15 amp (short) fuse. Blew a few of them.
Scootdawg is offline   Reply With Quote
Old 10-31-2014, 02:43 PM   #4
As said its fused separately and has its own circuit. You'll also find as a safety measure it won't extend or retract with the engine running (or in gear...one of the two).
2011 Sunseeker 3170DS - 30,000 miles explored
funfinder5 is offline   Reply With Quote
Old 10-31-2014, 07:29 PM   #5
As stated before this is normal. Also note that the slides, generator start/operating circuit , big foot jacks, and chassis alternator charging of the batteries will function with the switch in Off. The converter when plugged into shore power will not charge the batteries with the switch in Off except on late 2014 and beyond models with progressive converters.
ATVer is offline   Reply With Quote
awning, power
