02-25-2015, 01:51 PM
Power for camera
Looking to DIY a wireless camera on my Sunseeker and need 12v power on the rear for the camera. What might be the easy way to get power to the camera?? Thanks in advance
Jerry. Vietnam vet.
Retired
02-25-2015, 02:11 PM
12 volts
I use the rear tv power hook up for a second camera. There is 12 volt under the bed to access off the coverter if norhing else.
Hoglou the DH & BK the DW (retired and happy)
WestGA KM4HQQ 146.640mhz
Check out the "mods" in the albums
02-25-2015, 02:45 PM
Hoglou, how did you go up the back wall?
Jerry. Vietnam vet.
Retired
02-25-2015, 03:05 PM
Driiled a 1/4" hole with a 1/8" slit in the corner of the bed platform, did the same on the foot of the bed to go to the 12 volt plug. This allowed me to slide the wire in the bed platform. I am in a 2300 where the bed backs up against the back wall under the back window where my second camera is. If I was pulling power from another source I would prefer to use power that is switched on only while driving.
02-25-2015, 03:37 PM
I my try picking up power from my running lites, as I drive with them on most of the time... thanks for your help
Jerry. Vietnam vet.
Retired
02-25-2015, 05:17 PM
Will you have the camera inside or outside of the coach?
02-25-2015, 06:15 PM
I only thought of the outside I guess I didn't think of an inside mount. Looking out the window? Will that work. Inside?
Jerry. Vietnam vet.
Retired
02-25-2015, 06:18 PM
Btw Hoglou where is the first camera
Jerry. Vietnam vet.
Retired
02-25-2015, 06:25 PM
Factory camera outside top of rear of the coach (looks down towards the jeep bumper, the screen is the mirror. Te second camera (wireless) is inside looking out the back window over the jeep, screen is mounted on dash.
02-25-2015, 07:13 PM
Ok I got it mine does not have any camera now. So I could get good picture from the inside camera
Jerry. Vietnam vet.
Retired
02-26-2015, 03:53 PM
I can't check this for sure right now but, doesn't the round 7 wire trailer connector have a live 12 volt wire?
My work truck does, when the key is on anyway.
02-26-2015, 03:58 PM
You are probably right about the 7 pin I will check it out thanks
Jerry. Vietnam vet.
Retired
02-26-2015, 05:43 PM
Power aside, the issue I think will be getting the camera high enough (and not showing the wire). The advantage of inside is longitivity unless you go with a higher quality exterior unit. My second camera mount is shown in my album....
02-28-2015, 08:01 PM
Update::: I installed the camera found power within 6 ft Made the install inside and camera is adjustable for distance and angle. There is no interference when walking inside or motor, radio,gps. Thanks for all the help and ideas.
Jerry. Vietnam vet.
Retired
