Old 04-18-2013, 01:43 PM   #1
Power step not working STUCK OUT!!!
2004 SS 3100
I stored my RV with the step out, now it will not shut once all power is on & rv running. It did this to me a 4 months ago but then started to work again. when I started it up a month ago it worked. Its like it got stuck out. Is there something I can grease or bang on to help it out. Maybe motor is bad or something. Is there a manual close option? Any help would be much appriciated.
fmf421 is offline   Reply With Quote
Old 04-18-2013, 02:17 PM   #2
bclemens's Avatar
I would use liquid wrench on ALL the moving parts underneath. Those things have a tendency to rust.
PLEASE do not send questions via Private Message, my inbox fills up too quickly. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Old 04-18-2013, 02:59 PM   #3
This happened to me and the board went bad. The boards are expensive but easy to diagnose if you can remove the the 3 bolts and 2 plugs. There is a hot , ground, door switch and ignition wire. My door switch lead would not wotk because of bad board. Just run a 12v to hot and ground. Then jump to door switch.
bigdog1001 is offline   Reply With Quote
