Old 09-13-2016, 04:56 PM   #1
Frankie Z's Avatar
Power washer
Woul appreciate any pros or cons on using a power washer to wash my RV
Frankie Z is offline   Reply With Quote
Old 09-13-2016, 05:18 PM   #2
Flybob's Avatar
Used properly by an experienced operator, they can do a nice job safely. Used incorrectly by an inexperienced person it can lift caulk and remove decals. My last TT has a caulking leak caused by the wash person at the dealer using a power washer to speed up the process.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 09-13-2016, 07:41 PM   #3
DaveSchwartz's Avatar
I was told not to do it because you could easily peel off your decals.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is online now   Reply With Quote
Old 09-13-2016, 08:31 PM   #4
Frankie Z's Avatar
Thanks I think I'll stick to using a brush and garden hose
Old 09-13-2016, 08:42 PM   #5
Blackhat6mike's Avatar
Send a message via Skype™ to Blackhat6mike
The truck stop wash cleans my Aviator twice a year and they use pressure washers. Since I don't have caulking, decals or trim, it's no problem. The seal around the door to our outside entertainment center leaked a few drops until I replaced the door seal with a heavier seal.
A pressure washer WILL remove decals in a heartbeat.
2013 Silverado 2500 HD Duramax/Allison Tuned
Aviator Wright Flyer #1919
"First In, Last Out". 11B4Y
DAV, MOPH, VFW, 5/7 Cav,1/8 Cav Assoc.
11th ABN Pathfinder Co. N7MIP
Blackhat6mike is offline   Reply With Quote
Old 09-14-2016, 06:18 AM   #6
I use a pressure washer to do the first rinse, then I use a window washing mop on a pole to scrub the high areas and a hand held mop for the reachable areas, then the pressure washer for the rinse. The Sunseeker turns our real nice.
If you want to do fancy finish, you can always use a window washing squeegee to get the water off the windows and the fiberglass surface after the final rince. I usually try to wash my rig on a cloudy day and let it air dry.
The trick, use the 45 tip on your pressure washer and keep it about three feet away from the surface.
I do have a MBS Sunseeker and it is fiberglass with the decals clear coated on so I don't have to worry about the pressure washer lifting any decals.
Hope this helps, Sherman
ShermanD is offline   Reply With Quote
Old 09-14-2016, 06:53 AM   #7
BamaBob's Avatar
Best RV Wash solution ever!
Aircraft RV Cleaner Waterless Wash Wax Detailing Products Supplies
We have been using this for several years now and would never consider water and soap or a pressure washer ever again!
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is online now   Reply With Quote
Old 09-14-2016, 07:17 AM   #8
Witch Doctor's Avatar
Well I learned the hard way, I removed part of my decal with it. But I also had the most powerful nozzle on. I now use a 89.00 power washer with a fin type nozzle I thinks it's like 1600 psi. But I also stand back 4 feet when I use it. It will work well at that pressure but still try not to close to the decals. It will peel them off in hot second...
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 09-14-2016, 07:30 AM   #9
RollingDownTheHighway's Avatar
Why? With a good hose nozzle and good cleaner, you can do just as good a job without the risk of using a power washer. I've seen people, break windows, dent, crack, remove paint, remove decals, etc. with using a power washer on an RV.
Though can you, sure, with the correct nozzle.
2013 Prime Time Tracer 3200BHT
2016 Chevy 3500 CC, DRW (aka: bigbootyjudy)
Ribs in the smoker and Whiskey in hand
RollingDownTheHighway is offline   Reply With Quote
Old 09-14-2016, 07:30 AM   #10
I use this as well. Works amazingly.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2016: 38 nights camped
Teamfour is offline   Reply With Quote
power
