Old 05-26-2014, 08:08 AM   #11
Yes on a 3170
Fozzy is offline   Reply With Quote
Old 05-26-2014, 09:12 AM   #12
My other bins are fine just this one.
They ought to specify a weight limit or strap the bottom of the bins.
I'm gonna look at that and see if I can figure it out.
MikeRP is offline   Reply With Quote
Old 05-26-2014, 09:48 AM   #13
Frank & Eve's Avatar
Ours is Forester 3011 and just the one area is the problem. If you get it figured out post what you did Mike.
Sent from my MB886 using Forest River Forums mobile app
Frank & Eve is offline   Reply With Quote
Old 05-26-2014, 05:59 PM   #14
I asked for a weight limit on the storage bins and nobody at the dealer seemed to know.
jst3 is offline   Reply With Quote
Old 05-26-2014, 09:01 PM   #15
compartments
Have mine in for warranty work now, Mine is both the drivers and passengers side, screws are all pulled out and the plastic is pulled away. the screws are all stripped out, the black silicone sealant was a joke, most of it was never sealed from the factory. you can see the ground from the gaps. had road dirt and water coning in, Not sure what they have done to fix it, will find out tomorrow.
Kevin & Judy is offline   Reply With Quote
Old 05-26-2014, 09:13 PM   #16
Please let us know what they do! Thanks
Old 05-27-2014, 07:24 AM   #17
Brian. Any advise? I'll look at my 2015 in a couple weeks
Phelpo
phelpo is offline   Reply With Quote
Old 05-27-2014, 03:10 PM   #18
GM
bclemens's Avatar
1. it's not particle board. The surface material is probably lauan plywood, but the substrate will be aluminum framing. If it has broken loose due to weight, I personally would use an anchor type fastener/molly on at least a few of them.
They are typically rated for 200lbs but the problem is when that is not evenly distributed and secured. Way back in the back like that...rule of thumb is always at least 5 times. When we rate our LP tank, we have to test for 5 times the actually weight due to bouncing. So that 50lbs tool box becomes 250lbs pretty darn quick.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 05-27-2014, 04:38 PM   #19
OK well if it's not particle board it's something that looks just like it and the screws spin and will not tighten. You mentioned on the Forester link that the black storage bins have been replaced with gray which are more stable. Unfortunately ours are the black ones. We will see if the repair that DH did holds if not it will be in for warranty work.
Old 05-27-2014, 04:41 PM   #20
GM
bclemens's Avatar
More stable for shrinkage...this looks more like damage from a bouncing weight that may have broken it loose. Maybe those screws are missing backer or aluminum tube. Again a hollow core door anchor might be a better fastener in that case.
storage
