Old 02-10-2018, 07:04 PM   #1
JoeSteiner's Avatar
Propane bleed valve not bleeding
Went to have my propane tank filled at the local UHaul. The guy there said he couldn't top off my tank because my bleed valve was not opening. As I understand it, the bleed valve has a tube that sits at 80% of tank capacity so when you go to fill the tank you fill it up to the point where liquid propane sprays out of the bleed valve. This prevents overfilling and running liquid propane through your distribution lines.
I suggested he rap on the valve with a screwdriver handle but he said that might cause a spark. He was able to add two gallons to my tank. I always thought that propane was measured in pounds. But there's a lot I don't know about a lot of things.
I went on my trip and my heater and stove worked fine. Control panel says 2/3 full which is about as full as it ever registers.
When I got back I tried rapping the valve with a plastic handled screwdriver. Tried it in both the open and closed positions. Tried opening it all the way up hard and closing it all the way down hard.
I've heard they put a chemical in the propane so you can smell it. I've also heard that it is oil based and can gum up valves. I remember fixing my propane oven by banging on the control knob with a screwdriver handle.
It is cold here now. Ranging 20 to 60 degrees
Anyone had similar issues. Wondering if this is an RV dealer thing or a propane dealer thing.
Any advice appreciated.
JoeSteiner is offline   Reply With Quote
Old 02-11-2018, 02:44 PM   #2
SeaDog's Avatar
Yours is an installed tank so I think taking it to a propane shop and having them evacuate the tank and pull the overflow valve and clean or replace it would be the way for you to go.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 02-11-2018, 02:51 PM   #3
2012 Solera
Several on the forum have reported regulators freezing up from moisture in the propane tank. You say it is quite cold. Could this be a different presentation of the same problem (moisture in the tank)? Wait until things warm up and try it again?
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 02-11-2018, 02:55 PM   #4
Flybob's Avatar
This Thread should help with some of your questions. Not sure about purge valve. It could have been over tightened on earlier fill.
Propane Cylinders (Refilling vs Exchanging)
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-11-2018, 03:56 PM   #5
JoeSteiner's Avatar
Sea dog. I think that is probably the way to go. I opened the valve and rapped on it several times with a screwdriver handle and it would not release. Normally, on plumbing piping I would resort to a blowtorch and heat the valve up, figured that's not a good idea on a propane tank. Guess I'll try to find a "propane shop". Never looked for one before. Got any suggestions on what to search for?
Old 02-11-2018, 04:52 PM   #6
wmtire's Avatar
That FAQ is actually more concerning the portable type DOT cylinders. The ASME type cylinders in motorhomes are a little different.
However, I just found and added a great file to our library, which is a training manual written by the Propane Education and Research Council, that details properly dispensing propane in about all situations...inclusive of DOT, ASME, Vehicles.
Page 49 details the proper way to fill ASME cylinders in motorhomes.
Forest River Forums - Downloads - Propane Dispensing Training Manual
I am also going to update that FAQ to include a link to this.
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 02-11-2018, 05:27 PM   #7
SeaDog's Avatar
To have this type of thing done I would you need to contact one of the propane distributors (not the little tank fillers) in your area if they don't do that sort of thing they may know someone that does
Retired Navy
Old 02-11-2018, 06:03 PM   #8
MNtraveler's Avatar
If it's frozen, you might try parking indoors at 60 degrees+ for 24 hours. Either a storage building, an RV dealer's service bay, or even a service station with a tall bay (or truck service center). See if it thaws then works after that, and fill it right up if it does.
2016 FR Forester 2401R
Towing 2014 Honda CR-V
MNtraveler is offline   Reply With Quote
Old 02-11-2018, 06:09 PM   #9
JoeSteiner's Avatar
Gentlemen, thanks for you feedback. Not in a rush to go anywhere right now so I think I'll wait for a warm day an try it again. If that doesn't work I'll have it serviced.
Old 02-11-2018, 06:20 PM   #10
campingbaba's Avatar
On the end of the bleeder valve there is a rubber gasket . It will come of the bleeder and get stuck in the valve . The repair is simple . Take it to a propane dealer and they will take the bleeder out and replace the seal . When they take the bleeder out and the tank is below 80% only a small amount of vapor will come out . The bleeder hole is only a small hole .
campingbaba is offline   Reply With Quote
propane, valve
