Old 03-17-2015, 01:39 PM   #11
Hoglou's Avatar
Got it. Do not attempt.....
Hoglou westGA
KM4HQQ 146.640mhz
Old 03-17-2015, 02:20 PM   #12
Average Joe
MrJoe's Avatar
Wonder if you added a regulator to the bottle first.....
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 03-17-2015, 02:37 PM   #13
SaubleGuy
Technically that may work, however, you have to remember that gas systems are designed to work in a specific direction for a reason ie pipe size typically starts out larger at supply. I would never recommend doing this.
If you need to use a larger tank for extended stay periods, replace one of the original propane hoses with a longer one that will reach out to the external tank. It could be coiled and ziptied during normal use.
My $0.02
Saubleguy is offline   Reply With Quote
Old 04-21-2015, 10:35 AM   #14
Depends on your grill
In my previous post, the "extend a stay" adapter is placed between the onboard tank and the regulator. The kit has a connection port for the gas grill. My gas grill (Weber Q2000) has a regulator built into it. This is typical of grill that will take either an 1lb propane bottle (the little green ones) or the usual 20-30lb propane tanks. In either case the grill's regulator is all that is needed.
Since we are talking the usual "portable" grill I assumed that we were all on the same page. My mistake.
murf259 is offline   Reply With Quote
propane
