Old 10-06-2015, 05:55 PM   #1
Propane problem
So I took a trip this past weekend and used the propane Friday for heat and fridge. Turned the propane off Saturday morning when we left the MH for a few hours. Upon returning we needed to use the oven, I went to open the propane tank and I'm not quite sure what happened??? I think I had it turned all the way left(open) and all of a sudden I couldn't turn it in either direction- it is stuck tight, won't budge a bit either way. The tank is full and I don't now if somehow the pressure made the knob get stuck. Can't even be sure it is in the open position cause when I tried running the heat after it got stuck it wasn't blowing out any hot air. Any help anyone can give would be appreciated, can't get an appointment at the dealer till after my next trip and I'm gonna need the heat. Thanks everyone!
beachbum107 is offline   Reply With Quote
Old 10-06-2015, 06:30 PM   #2
oldgold's Avatar
You can check to see if it is in the open position by turning on a burner for a little bit on the stove. I would take the trailer and all to a propane dealer. They can probably help you a whole lot quicker than an rv place.
2015 XLR Nitro 30FQSL
2015 F250 King Ranch
oldgold is offline   Reply With Quote
Old 10-06-2015, 06:32 PM   #3
a very quick answer ... disconnect your propane tanks ... turn them both to all the way off positions as indicated on the handle/turn off thingy ... then reconnect the propane tanks ... then turn both on ......
trust me .. this is not an issue .. most of us here have struggled with this issue the first time and all freaked out ...
d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 10-06-2015, 06:41 PM   #4
D-mo,
Don't want to sound like too much of a newbie, but how do I disconnect? I have a 3170ds model, is the hose I should disconnect under the plastic cover in the propane compartment?
I will be very happy if that will help release the pressure and let me get the knob to turn. Thanks I will give this a try over the next day.
Old 10-06-2015, 06:43 PM   #5
BendOrLarry's Avatar
He said it won't turn either direction, it's stuck.
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
BendOrLarry is offline   Reply With Quote
Old 10-06-2015, 06:50 PM   #6
Yeah no problem at all you have to do with this is remove the 2 screwing cats that are on your propane tanks turn both tanks off before you remove the cats let them set for about 30 or 40 seconds reinstall the caps onto your propane tank then turned either one or both on whichever you wish this should solve your problem new sentence this was done by Google Voice and cats should read plastic cap
2011 Rockwood A122
Old 10-06-2015, 07:00 PM   #7
Cannot turn the valve to either open or close- it's stuck, I'm guessing it's frozen
Old 10-06-2015, 07:48 PM   #8
Guys the OP has a motor home which has the propane tank welded to the frame you cannot remove it. If he can't get to a RV dealer I would take it to a propane supplier.
2016 Sunseeker 2700DS
2010 Jeep Liberty Toad
tlf65 is offline   Reply With Quote
Old 10-06-2015, 08:26 PM   #9
Head Rambler
Try running the stove and see if it has a good high flame on all burners. If so the valve is open and it should run the furnace.
If it's not open then I agree with taking it to a propane dealer.
Gotta go campin!
Old 10-07-2015, 01:19 AM   #10
Mike968's Avatar
Propane problem
Try a pair of channel locks first, gently I might add... Remember the rule: Lefty loosey, Righty tighty.
See if you have gas at the stove, if you don't then your valve is most likely stuck shut, so lefty loosey with the pliers. Unless that valve is visibly rusty or visibly damaged in some way I highly doubt you need to take it anywhere.
Mike968 is offline   Reply With Quote
propane
