Old 09-21-2014, 10:26 AM   #1
Propane Question
Hello all,
I took my 2011 Sunseeker 2860DS out for the first time (bought it used) and was unable to get anything to work on the propane. Can someone tell me how to get the gas on and working. I turned the gas on outside and when I went to light the stove it didn't work. The rig didn't come with an owner's manual so I'm kinda winging it. Any help would be great.
Jaydee0107 is offline   Reply With Quote
Old 09-21-2014, 10:52 AM   #2
If the gas valve is open it'll automatically ignite once the system fails as the purge the air. Also check that somethings getting through a lot of bad gas regulators.
DrJMB is offline   Reply With Quote
Old 09-21-2014, 10:59 AM   #3
You are sure the tank has propane in it ?. Dont always believe the gauge. If it has not been used in a while it may take a while for the propane to get to the stove burner, Take a bit of time to get all the air out.
Kevin & Judy is offline   Reply With Quote
Old 09-21-2014, 07:08 PM   #4
Wiscampsin's Avatar
Make sure you turn the LP tank valve on very slowly.
2013 Palomino Sabre 34REQS-6
Link to pics:
Wiscampsin is online now   Reply With Quote
Old 09-21-2014, 07:13 PM   #5
Iwannacamp's Avatar
And in my case... Wait at least 15 minutes to turn anything on except the tanks. Otherwise I am SOL.
I found a two stage regulator at tractor supply on "scratch and dent". It was $40. I said never mind. Thank you.
totalled 04-11-16 by storm(picking up new one 10-26-16)
Old 09-22-2014, 03:46 PM   #6
ourflat's Avatar
I had to replace my regulator! $35.00 at Camping World!
2016 Days Camping so Far: 24
2013 3051S Forester
2013 Elantra GT (Toad)
WashU EMBA "39
ourflat is offline   Reply With Quote
Old 09-23-2014, 10:03 AM   #7
Garrette's Avatar
Turn off the tank valve. Disconnect your regulator from the tank. Let sit for 15min. Reconnect and turn tank valve on slowly. Very slowly. This should reset the regulator.
Garrette is offline   Reply With Quote
Old 09-24-2014, 07:10 AM   #8
trdutch's Avatar
Propane Question
There have been reports of defective regulators
Mine failed and I lost the entire tank of gas
Replaced under Warranty and refill for free (good people at Campers Inn)
When I turn gas on I always light my stove to get gas flowing and air out of system that way I don't fret over Refig and hot water faulting
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
trdutch is offline   Reply With Quote
