04-24-2015, 05:47 PM
Propane question?
When I purchased my 2015 3010ds, I had the dealer install a tee in the propane system to allow me to run my grill. My grill has a regulator, and the tee was installed before the regulators for the coach. From what I understand everything should be correct at this point. When I am cooking on the grill, no problems. But when you start one of the burners on the stove, I loose all propane at he grill. Any thoughts?
04-24-2015, 05:56 PM
Your grills regulator needs more gas then the rv's regulator can give it. It just wont work.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
04-24-2015, 05:57 PM
So what do I need to do?
04-24-2015, 05:59 PM
There are 2 small regulators on my coach, is that normal?
04-24-2015, 06:02 PM
His "T" is before the regulator and should be getting full pressure. Grill works fine until he uses the cook top.
You won't be able to cook on both at the same time. It sounds like it's plumbed right.
04-24-2015, 06:03 PM
Just take the regulater off the grille and hook the RV supply line direct with a proper quick connect with a shut off ,as are made for that.Otherwise you will be regulateing the supply twice and it will work,but the burner output will be only about 50%.
edit)just reread the OP,thought you were T ing off the RV supply line under the trailer.If you are tapping in before the RV regulater,then you will need to cut the pressuer down with the grill regulater. Ive never seen it done that way and would not want the unregulated supply line underfoot at the campsite.
04-24-2015, 06:06 PM
Can you take a picture of the T connector and the 2 regulators?
04-24-2015, 06:07 PM
"My grill has a regulator, and the tee was installed before the regulators for the coach."
He is NOT regulating the gas to the grill twice, the grill line is in front of the main regulator.
04-24-2015, 06:08 PM
If is T is before the regulator that could be an unsafe idea to remove the grills reg.?
Seasonal
04-24-2015, 06:13 PM
Path of least resistance.
Likely the line going to the stove is larger than the line going to the grill.
I would move the T down line from the stove.
04-24-2015, 06:16 PM
Yeah,he needs the grill reg in that case,see my edit above.
04-24-2015, 06:20 PM
On both of my trailers the T is in the regulated side of the system. The RVQ works fine with no regulater. The rubber line to the grill is only 3/16" ID,and mine is 20' long.
04-24-2015, 06:21 PM
This is what I have, hope this comes through.
04-24-2015, 06:32 PM
you need the reg on the grill.
04-24-2015, 06:36 PM
X2
04-24-2015, 06:42 PM
Is this not a regulator on the grill?
04-24-2015, 06:47 PM
Yes,you should be good to go.
04-24-2015, 06:51 PM
What type of grill do you have? From the pics, it looks like a roadtrip that uses a 1 lb. bottle with an adapter hose.
04-24-2015, 06:52 PM
I agree, but what I have described above is taking place. So, what's up?
