Old 05-15-2018, 02:40 PM   #1
Pump runs but no water comes out/ problem solved - thanks
Iím doing the de-winterizing and every thing seemed fine until I turned the bypass under the shower to RV normal operation. Now my pump just keeps running and no water comes out of the facet. It seems to be ok if I turn on the city water. I do not see any leeks in the motor home or underneath RV. Any help would be appreciated! Thanks in advance.
sunseeker56 is offline   Reply With Quote
Old 05-15-2018, 02:43 PM   #2
jd50i's Avatar
Is there water in the tank?
jd50i is offline   Reply With Quote
Old 05-15-2018, 02:50 PM   #3
What does what I emboldened in blue above mean?
Meaning, you have water in the fresh tank and the pump was drawing water from the fresh tank but stopped when you turned the bypass valve?
And this bypass valve... are you referring to the winterization valve (that selects either drawing antifreeze into the system or drawing from the fresh tank) or the bypass valves on the water heater?
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 05-15-2018, 02:52 PM   #4
sgtlm17's Avatar
Either empty fresh water tank or more likely winterize hose is on and valve needs to be turned. Possibly even water heater filling up first
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 05-15-2018, 02:56 PM   #5
This is our first time to do this. So I didnít fill the tank in the back of RV that says potable water only. Is that my problem?
Old 05-15-2018, 02:59 PM   #6
I followed steps in book and had it hooked up to city water then I ran out all the antifreeze and then I turned the handle under the shower to normal operation and waited about 10 minutes before I turned off city water. Then I turned on water pump and could not get water to come out. Pump would run.
Old 05-15-2018, 03:01 PM   #7
fonzie's Avatar
Yes tank needs to have water in it to be able to use water pump.
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 05-15-2018, 03:02 PM   #8
I think that might be it! Let me fill that and see. I was thinking that hooking the hose up on the side would fill that tank but you are saying that the tank needs filled by another fill on the back of RV.
Old 05-15-2018, 03:04 PM   #9
jd50i's Avatar
I don't know about your RV but mine has a "city water" connection that bypasses the tank so the pump is not used and a "tank fill" that fills the tank. The pump draws from the tank.
Old 05-15-2018, 03:14 PM   #10
Thanks so much!! That was it!
pump, water
