Old 04-19-2017, 12:23 PM   #1
Question about Water Lines
I recently bought a used 2007 Sunseeker 3100 and it has a pair of plugged off water tubes extending down about a foot through the floor in front of the battery box. I have not been able to trace their routing. Can anyone suggest what they are for?
Underdog is offline   Reply With Quote
Old 04-19-2017, 12:38 PM   #2
spierce617's Avatar
They are drains for the cold and hot water lines.
2005 Winnebago Adventurer 38R
Workhorse 8.1/Allison Transmission
Old 2005 Forest River Cherokee Lite 28A
spierce617 is offline   Reply With Quote
Old 04-19-2017, 12:47 PM   #3
MacGumbo's Avatar
I wish mine were that easy to get to. Mine are between the axles to which I can't slither under unless I jack up one side.
2020 Grand Design Reflection 240 RL
2006 F350 Lariat Crew Cab Super Duty 6.0 diesel 4X4
MacGumbo is offline   Reply With Quote
Old 04-19-2017, 12:47 PM   #4
bikendan's Avatar
H & C low point drains for winterization.
Old 04-19-2017, 01:54 PM   #5
trdutch's Avatar
As a note
I added shut off valve to the hot line where it lives in my water pump compartment
I hit road debris once and the cap was knocked off the hot drain line and there was no way to stop it from draining without a spare cap
The cold already had a shutoff valve
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
trdutch is offline   Reply With Quote
Old 04-19-2017, 03:50 PM   #6
Hoglou's Avatar
Dea49,
Reroute those critters. Lowes has the pex line, connectors, crimper, and cut off valves. Takes longer to replace the foam (bug deterrent type, at ya.. lowes) the way you want it then to fix the problem. I did not want my water subject to plastic cut offs exposed to the under belly, if they crack or fail you will be back to tent camping where water is concerned, for in take and discharge if you get my meaning.
I dont take a knee for nothing or nobody but the the big guy... if I crawl under the coach it is to fix something.. take a look at my albums..
Hoglou the DH & BK the DW (retired and happy)
WestGA KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 04-24-2017, 04:32 PM   #7
Where are your albums posted? Thanks.
Jersey Jim is offline   Reply With Quote
Old 04-25-2017, 09:06 AM   #8
Hoglou's Avatar
Click here
Click on my name Hoglou on this posting (top left) go to public profile, albums are on the right.
water
