Old 02-18-2016, 05:09 PM   #1
Question for Josh
We have a 2014 3010 and I need to locate a sturdy mounting point where the folding door attaches to the frame in the rear bedroom. My wife is a stroke survivor and I need to ad an assist bar to aid getting her into the bed. I don't want to poke a hole in the shower. Also can you tell me if there is any horizontal mounting point on the common wall (bedroom/toilet) to mount a small assist bar. Thanks
rekwiat is offline   Reply With Quote
Old 02-19-2016, 02:58 PM   #2
Class C Representative
Joshua Cavitt's Avatar
There should be a vertical stud in the back bedroom by the folding door that you can tap into.
The bathroom will have two vertical studs about 18 inches away from each other.
Will she just be using it to get around or for full weight support?
PLEASE do not send questions via Profile comments or Private Message, my inbox fills up too quickly. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Joshua Cavitt is offline   Reply With Quote
Old 02-19-2016, 03:03 PM   #3
Thanks Joshua for your quick reply. These assist are more for stabilizing . Are the studs 2x2 wood or aluminum tubing?
Old 02-19-2016, 10:25 PM   #4
Following
rlchall is offline   Reply With Quote
Old 02-22-2016, 11:10 AM   #5
If you're going along the sidewall, ceiling, floor, or back wall it will be aluminum. Anywhere else in the coach will be wood.
Old 02-22-2016, 05:50 PM   #6
namusmc's Avatar
I have seen short grab bars in hardware stores that are heavy plastic and use large suction cups for anchorage to a shower wall. This might be a better alternative than drilling holes. Just a thought.
namusmc is offline   Reply With Quote
