Old 08-28-2015, 07:54 AM   #1
Radio signal
2014 sunseeker. How's your radio play? Stations just keep coming and going in mine. Anyone change antennas or try and move there's
retired on a mountain is offline   Reply With Quote
Old 08-28-2015, 09:36 AM   #2
trdutch's Avatar
I'm all ears,cause I can't get Charlotte stations and 18 miles to the west (no interference)
Can someone please tell me why you can always get country and R&B?
This country was built on Rock n Roll
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
trdutch is offline   Reply With Quote
Old 08-28-2015, 02:38 PM   #3
Wait till next year...
n-e-d's Avatar
Must be the radios all I get is PBS
Mary and Me
2015 2650s "Finally" SOLD
2015 Jeep Cherokee Toady
2023 Geo Pro FD19 "Almost there"
2022 Race Car Red HR Long Ford Transit 250 "The Iwish Roamer"
n-e-d is offline   Reply With Quote
Old 08-28-2015, 02:51 PM   #4
JimOneil43's Avatar
Probably because you're in the south. go to Minnesota and you probably won't get the country.... LOL
Retired and loving it...Can't wait to get back on the road!
2017 Forester 3051S ("Farley")
Born April 18, 2016
Toad: 2014 Honda CR-V AWD
GO DUCKS !!
Jim & Diana (and 3 cats)
JimOneil43 is offline   Reply With Quote
Old 08-29-2015, 06:35 AM   #5
trdutch's Avatar
That's a fact!
But on a serious note,has anyone come up with a mod or solution?
Amp? Power booster?antennas?
'78.....tents
Old 08-29-2015, 07:48 AM   #6
i was thinking of getting a hidden antena. like they sell for motorcycles friend has one on the inside of is harley fairing just a wire in plastic tape maybe 30 in long and try under hood .
Old 08-29-2015, 07:56 AM   #7
strat56's Avatar
If you do a search on here, I believe you can connect your radio to your TV antenna and get much better reception.
Jack and Jan
Nights camped 2014 - 8 | Nights camped 2015 - 23 | Nights camped 2016 - 24
2015 Ford Super Duty F350 > Blue Ox Swaypro WD Hitch > 2015 Rockwood Windjammer 3008W
strat56 is offline   Reply With Quote
Old 08-29-2015, 08:32 AM   #8
Send a message via AIM to jk31668
on my 2010 sunseeker, ford chassis, i get good reception if the station is out in front of me but if the station in located behind me, the signal seems to get blocked by the metal in the rig?
2010 sunseeker 3100ss
jk31668 is offline   Reply With Quote
Old 08-29-2015, 08:33 AM   #9
I have one of the 2012 and earlier model Jensen radios that seems to work fine on free radio. However I added satellite to it and rarely listen to regular radio anymore. Once you have satellite you'll never go back. It has a portable receiver head and can be moved from vehicle to vehicle as well as connected to a portable boom box that can be used in the house or anywhere outside.
ATVer is offline   Reply With Quote
Old 08-29-2015, 09:06 AM   #10
Toy-aholic
I added a little do-hickey module to the aux jack & stream Pandora from my phone via bluetooth......much better
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
Old 08-29-2015, 09:11 AM   #11
DAISY BOYKIN's Avatar
Bad Radio Reception
Bad radio reception? Try grounding the radio. Don't know where your radio is mounted in your RV, but the chassis of the radio has to grounded.
If you can not receive any AM stations but spotty FM stations your antenna
for the radio is defective or the radio is not grounded. In order for the radio
to work properly the radio case (metal) has to have a ground wire run to the RV's metal body or frame. First to test to see (easiest) if the antenna is defective, just simply run a ground wire to RV's frame. The ground for the
radio's 12 VDC grounding is isolated from the chassis. A separate ground must be run!
28 years in the radio business!
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2023 69 DAYS
[SIGPIC][/SI[SIGPIC]
DAISY BOYKIN is offline   Reply With Quote
Old 08-30-2015, 07:21 PM   #12
This problem has been discussed here numerous times. If you have a class C, expect horrible AM radio reception on your cab radio due to the antenna being located under the front overhang. FM reception is not affected as much. Having had two Class Cs before ordering my 2860, I requested the cab radio antenna to be located on the coach roof, which was done for an additional cost. (I believe this is standard for the Solara). AM reception is definitely better.
KQ2N is offline   Reply With Quote
Old 09-04-2015, 08:23 AM   #13
Had the same problem, especially on AM side. Coastal RV in Carrolton, VA, young tech came up with idea to use the TV antenna on top and splice into radio, bypassing under front roof antenna. Works great and long, clear reception. Took about 1/2 hour and under $50 for splitter and wire.
Gchpazi is offline   Reply With Quote
radio
