Old 05-10-2016, 08:37 AM   #1
range hood flap
just picked up our 2400ws. Does anyone know how to open the the flap for the range hood vent? I've pushed up and pulled down on what appears to be the locks but the flap will not open, afraid if I apply too much pressure either way I'll break something.
Skip51 is offline   Reply With Quote
Old 05-10-2016, 08:39 AM   #2
karrun's Avatar
Very very hard to open. I use a small flat blade screw driver and pull at the same time. I hate the design. It shouldn't be that hard.
The flaps on ours open by pulling towards the outside, not down.
2016 Roo 21SS
2005 Ford Excursion-Sherman
Mods so far:
PI hardwired EMC, Wire Shelving in wardrobe
Plexiglass screen door protector, Blue LED Wine nook
stairs, and counting...
karrun is offline   Reply With Quote
Old 05-10-2016, 09:11 AM   #3
Flybob's Avatar
Some of them have small levers in each lower corner that turn over the flap to keep it form opening while traveling. If yours have them, just turn them so they do not hold flap in place. Then it snaps open and closed.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-10-2016, 09:25 AM   #4
See post #6 here.
Iwritecode is offline   Reply With Quote
Old 05-10-2016, 09:30 AM   #5
If yours is like mine I have the two lever locks on the bottom corners. Mine was stuck also and was catching on the right bottom corner circle of plastic surrounding the locking lever. Put a screwdriver under each corner and gently pry it open. I had to snip off a small piece of the flap on that right hand bottom corner with my tin snips for it to move freely.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 05-10-2016, 09:35 AM   #6
Pickin' & Campin'
My brother just picked up a new 29RKWS on Friday and the little release tabs on his had something on them that looked like adhesive or caulking.
It didn't seem as though it squeezed out from under the frame during installation.
It was almost like they glued them shut during transport.
We were able to get a screwdriver under the tabs and loosen them.
Once opened he cleaned the glue/adhesive from the tab area and they work as described in the link posed above.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 05-10-2016, 09:45 AM   #7
bob dirt's Avatar
Mine is painted shut so I did it from the inside. I didn't want to scratch it. I removed the aluminum intake filter from the vent hood and popped the door open using a large flat blade screwdriver.
2016 Forester 2401WS MBS
Life is short...eat the cookie
bob dirt is offline   Reply With Quote
Old 05-10-2016, 10:00 AM   #8
Oakman's Avatar
Put your thumbs on the bottom of the tabs and push outward.
Like this
Name:	IMG_7114 - Copy - Copy.jpg
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 05-10-2016, 10:09 AM   #9
Like this
Attachment 107426
x2
CNYCamper is offline   Reply With Quote
Old 05-10-2016, 10:13 AM   #10
Pickin' & Campin'
Like this
Yep...those are the tabs I referred to above that were glued shut.
No way would they come loose pushing on them with your thumb.
Had to use a screwdriver to initially break them loose.
