Old 06-12-2014, 06:27 AM   #11
It was the service manager....that is why I paid attention....However I am going to get them on because i am tired of pulling out the jacks in and out of the storage bin......plus the scissor jacks weigh a LOT less than the jacks I am using.......Anyone want an inexpensive pair of jack stands? LOL
Scooter81 is offline   Reply With Quote
Old 06-12-2014, 07:50 AM   #12
Scissor jacks will be fine on a class c as long as they are installed on the correct part of the frame and used correctly. Installing them out near the rear bumper on the frame extensions will put stress on an area of the frame and coach body that will likely cause damage especially if you try to level the coach with them. The safest place to install them is where the factory hydraulics jacks would be placed and is the only place I have seen factory installed scissor jacks. The other issue is that they are manually operated one at a time (not like hydraulic jacks that are operated in pairs) and can put twisting stress on the frame. However if you are only stabilizing not leveling with them you should not damage anything.
ATVer is offline   Reply With Quote
Old 06-13-2014, 11:36 AM   #13
Scissor jacks aren't made to level so, if you're lifting your class c at all with these you risk disaster. They work great for stabilizing though.
I bolted two near the back of our 3170 but I still haven't figured out a good front spot to hang a set. Like others on here, I just carry a cordless drill and they zip right up and down.
Sure beats the 5k price tag on auto levels.
Sent from my Nexus 10 using Forest River Forums mobile app
howzball is offline   Reply With Quote
Old 06-16-2014, 08:02 AM   #14
I agree with howzball, mounted mine at the rear of our
3011ds. That was the only place I could find to install
them. The cordless drill is spot on.
Phelpo
phelpo is offline   Reply With Quote
