Old 08-31-2013, 03:05 PM   #1
Ilockemup's Avatar
Rear bedroom speakers in Sunseeker 2860DS
Does anyone know if there is a way to run the RV stereo (in-dash) when set up at campsite? Speakers in back bedroom, so I would assume that you should be able to listen to radio when set up, why else would speakers be all the way back in bedroom. Radio has no power with key off. Any info would be appreciated. Thanks.
Ilockemup is offline   Reply With Quote
Old 08-31-2013, 05:05 PM   #2
What year is your MH? Recent units (at least) have dual power to dash radio, either from ignition or coach. Is power on in your coach (battery disconnect in ON position).
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 09-01-2013, 12:32 AM   #3
Ilockemup's Avatar
2006 Forest River Sunseeker 2869DS
I have never seen any switch to give the radio dual power. Only would work if you put the key to accessory or RV was running. Also checked the battery disconnect switch.
Old 09-01-2013, 07:25 AM   #4
MotocrossCamper's Avatar
A 2006 will not have a dual switch. Your ignition key does have to be on. On our 06 I found the power lead to the radio and ran a wire to the battery with a in-line fuse.
MotocrossCamper is offline   Reply With Quote
Old 09-03-2013, 01:10 PM   #5
Graduate Member
RoadTrip's Avatar
I've been wondering the same thing - and we have a 2009!
--2009 Sunseeker 2860DS (Class C)
- one Hotwife, and two boys under 2(with one on the way!)
2013 - 53 days
2012 - 26 days
RoadTrip is offline   Reply With Quote
Old 09-04-2013, 08:53 AM   #6
GM
bclemens's Avatar
We didn't start wiring off of the house batteries until 2010 0r 2011.
They're wired with a relay...so if you driving down the road it will work off of the chassis battery. Key off...they'll switch to the house batteries automatically.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 09-04-2013, 08:53 AM   #7
GM
bclemens's Avatar
make that "auto-magically"
