Old 07-04-2016, 07:05 AM   #1
rear camera
I have a 2013 3010ds and have a problem with my rear view camera. The camera now shows a side view when traveling down the road in drive. when I put in reverse it gos to rear view. what is wrong with my camera when my transmission is in drive,:confused why am I getting the side view camera when in drive.
thanks for any help you can give me with this Dale.
bikeit02 is offline   Reply With Quote
Old 07-04-2016, 07:16 AM   #2
Tinkerer and Putterer
Sounds like someone was clicking the camera buttons (up down arrows) on the screen to change the default camera when dirving. You should be able to twiddle those buttons to switch the backup camera back to default.
HappyGuy is offline   Reply With Quote
Old 07-04-2016, 02:13 PM   #3
I CLICKED THE UP DOWN BUTTONS last night with no luck I will look into this later today.
Old 07-05-2016, 07:31 AM   #4
You might consider pulling the panel below your steering column off and tweaking with the connections to the multiplexer. The connections are clearly labeled on the box and it's right there behind the panel. I might try disconnecting the side view camera connections and starting the vehicle to see if the screen switches back to using the backup camera as its default. If it did then I would reconnect the backup cameras to see if the change sticks. Should take less than 10 minutes to do that troubleshooting test. I have had a similar problem in the past and I was able to clear it by shutting off the RV, letting it sit for 30 seconds and then starting back up but your instance seems to be a bit more stubborn than the one I experienced.
Old 07-13-2016, 11:22 PM   #5
Red face rear camera.
pushed around on the buttons and all is working now. I have a grandson that loves to push buttons this is what could of happened to it.
Old 07-14-2016, 06:35 PM   #6
Chief tinkerer
Gidyupgo's Avatar
Bikeit, we have the same (blessing) problem when we take our 3yr old grand. Every time I sit down to drive after we camp with her I scan for switches and levers out of position. Hah, at least she learned "don't play with the beep beep".
Gary
2017 SunSeeker 3010DS
Gidyupgo is offline   Reply With Quote
