Old 10-24-2015, 12:12 AM   #1
Rear camera at night
2013 sunseeker. When leaving the rear camera on at night, the image is very washed out. I thought it was better before so maybe I messed up some setting. Although I looked and everything is basically on factory defaults. It's perfectly fine during the day. Do others have this problem?
All previous rigs below are sold - waiting until the kids graduate to the buy the next one!
'13 Forest River Sunseeker 3100 Class C
'04 Fleetwood Sedona Pop Up / Reese Mini 350 / Prodigy / BAL
'94 Coleman Cedar Pop Up
paulmlac is offline   Reply With Quote
Old 10-24-2015, 12:41 AM   #2
2012 Solera
Not great at night. If it used to be better, try cleaning the cameras lens. Mine seems to attract dirt - affects it more at night.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 10-24-2015, 12:55 AM   #3
Seems like it's a common problem with RV systems. Although I don't have my new coach yet, I can tell you that this problem existed in my last 3 coaches.
Seems like the manufacturers do not use day/night vision cameras. As a result, the camera cannot really adjust to the darkness. Then, when another vehicle's headlamps shine, the camera goes all crazy trying to adjust to a bright light against a black background.
This must be a "cost" issue. In my 2014 Ford Fusion, the rear view camera shows a clear picture at night. It does get a little confused if a headlight is shining on it, but in general I have a clear, bright picture at night. So the technology is there, but maybe the coach manufacturers use a cheaper type of camera system.
WayneLee is offline   Reply With Quote
Old 10-24-2015, 12:07 PM   #4
RedLdr1's Avatar
I have the same issue. Adding some additional back up lighting improved, but didn't totally fix, the issue. I think a couple more LED lights under the rear bumper, aligned straight out and parallel to the ground, may help. All the lighting I have now is located fairly high up and has very broad coverage...
Wayne and Christine
2020 Sunseeker MBS 2400Q On Order
RedLdr1 is offline   Reply With Quote
Old 10-24-2015, 05:54 PM   #5
Replacing my back up lights with LEDs (as well as my tail lights) made it very easy to see with the camera.Click image for larger version
Name:	ImageUploadedByForest River Forums1445727284.270441.jpg
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 10-25-2015, 12:28 PM   #6
Wingdreamer's Avatar
Originally Posted by RvBill3 View Post
Replacing my back up lights with LEDs (as well as my tail lights) made it very easy to see with the camera.Attachment 92753
LOVE your LED lights! Where'd you get them and if you don't me mind asking, what are they worth? I'm looking to replace my crappy incandescent lights and also wanted back up light capacity....
2015 Forest River Vibe 268RKS being pulled by a 2010 F150 Lariat 5.4l, 3.73 axle Super Cab, Max Tow with 11,300 lb tow capacity , Equalizer 4 point W/D hitch
Wingdreamer is offline   Reply With Quote
Old 10-25-2015, 01:33 PM   #7
I have LED lights all around and that is not the solution. I agree that the camera works well in daylight but is clouded at night. Also, the rear LED running and brake lights appear to further wash out the image at night.
David100 is offline   Reply With Quote
Old 10-25-2015, 03:34 PM   #8
Retired
Our backup camera is crystal clear at night, I just wish it would show up that clear during the day. At night it looks like a television set turned on, but during the day we have a hard time seeing the picture.
tennlady is offline   Reply With Quote
Old 10-25-2015, 04:52 PM   #9
NCIC105's Avatar
[QUOTE=Wingdreamer;1019418]LOVE your LED lights! Where'd you get them and if you don't me mind asking, what are they worth? I'm looking to replace my crappy incandescent lights and also wanted back up light capacity....[/QUOT
I like them also...Hope they post where they picked them up.
NCIC105 is offline   Reply With Quote
Old 10-25-2015, 06:21 PM   #10
RedLdr1's Avatar
See Here for the Bargman lights you'll need. They have kits for all the tail lights not just the Reverse lights. EBay, Amazon and a bunch of other places will have them...
Wayne and Christine
