Old 04-22-2013, 08:30 AM   #1
Red drain hose
OK. I'm confused. We have a '13 3100. Under the unit are two drain hoses, one blue and one red (see attached pic). I understand the blue one. I don't get the red one. Logic would indicate a hot drain. But I thought the only way to drain hot was to remove the anode rod. Also, when I unscrewed the cap last night, pink antifreeze came out. I drained our water heater by removing the anode rod so know there is no pink in there. In fact, the only place I put pink was down the various drains. So what is the red line for, what's "upstream", and when should I unscrew the cap? Thanks!
All previous rigs below are sold - waiting until the kids graduate to the buy the next one!
'13 Forest River Sunseeker 3100 Class C
'04 Fleetwood Sedona Pop Up / Reese Mini 350 / Prodigy / BAL
'94 Coleman Cedar Pop Up
paulmlac is offline   Reply With Quote
Old 04-22-2013, 08:52 AM   #2
Rugged Brown's Avatar
These are low point drains for the hot and cold water systems.
Terry/Bernadette
Lily the Yorkie
2019 Dodge Ram Sport 1500
2019 FR Vibe 28RL
Rugged Brown is offline   Reply With Quote
Old 04-22-2013, 09:07 AM   #3
Agreed from a logic perspective but doesn't seem right based on what I did.
- I removed the anode rod from the water heater to drain it. I thought that was the only way to drain the water heater based on the owners manual & what I heard. I didn't know I could just unscrew the cap on the red drain.
- I then blew out all the lines (opened all the cold / hot taps in so doing).
- And then I put pink down the drains only (i.e., not in the fresh tank & the water heater was on bypass so don't know how pink could have gotten in a hot line).
Thanks!
Old 04-22-2013, 09:16 AM   #4
The factory tests the system I imagine, so they would have winterized it before shipping it out. That is probably where the pink came from.
As for draining the hot water tank, you remove the anode rod as you said. The pictured low-point drain is not for that purpose.
I don't think you have anything to worry about.
bakken is offline   Reply With Quote
Old 04-22-2013, 09:17 AM   #5
wmtire's Avatar
Attachment 28664
Did you take the cap off of the blue/cold water line? I have a dark monitor here at the shop. but it appears there is no cap on it.
Your hot and cold low point drains will help get out the water that is in their respective lines......but not any water that would be trapped in any kind of reservoir (like a hot water heater or water filter and/or water pump).
As far as the pink, did you put any in the water pump or water filter when winterizing?
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 04-22-2013, 09:25 AM   #6
wmtire's Avatar
Thanks!
When you set to bypass, you are tying the cold water line to the hot water line......just bypassing the water heater itself. Basically your hot water lines, just become all cold water lines this way.
Even when not bypassing the heater, you have the cold water line inputting to the heater...... whereas the heater heats the cold water, then outputs the heated water to the hot water lines. Anything upstream of the hot water heater in the cold water lines, could get drawn into the water heater, then pushed out into the hot water lines.
The whole purpose of the bypass, is to keep the antifreeze out of the heater (thus not needing to fill the water heater with it, which could be six gallons or more). All of your lines (hot and cold) are then filled with antifreeze.
That's why I asked if you may have put any antifreeze in the water pump or water filter.......cause antifreeze in either would end up in the hot water line.
Old 04-22-2013, 12:08 PM   #7
Thanks!
You need to open the red cap to ensure all the water is drained from the hot water lines when you winterize. It may or may not drain the water heater as well. You should always remove the water heater drain plug/anode as well.
ATVer is offline   Reply With Quote
Old 04-22-2013, 05:20 PM   #8
The cold water low point drain has a valve in the compartment where the water pump is, so it does not have a cap on it. The red (hot) has a cap.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 04-22-2013, 05:43 PM   #9
wmtire's Avatar
Good deal. Thanks for the info.
Old 04-23-2013, 11:39 AM   #10
Cjhernandez's Avatar
I have a 3170DS 2013, I only see a blue drain hose. I thought there was supposed to be a red one for hot water also. Am I missing something?
Cjhernandez is offline   Reply With Quote
