Old 02-08-2014, 10:14 AM   #11
How to make your drawers/cabinets look good and quite
It was suggested to me to share what I have done with my last four
rigs to improve the look and quietness. Our new 3011ds is on order
and when it comes in I'm going to carpet the drawers and cabinets.
What I have been using is carpet runners. It is thin with a rubber
backing. I have purchased it from Lowes and HD. This has
improved the look greatly and cut down on a lot of noise. It does
not move around if you do a good job of cutting.
Hope this helps
phelpo is offline   Reply With Quote
Old 02-08-2014, 10:31 AM   #12
Sorry for the misinformation I think I had brain freeze from the cold spell we have had .
lbrunning is offline   Reply With Quote
Old 02-11-2014, 06:04 AM   #13
I am a retire Fire Chief tat hates propane but I use mine to run the refrigerator when driving. I do shut off the refrigerator when fueling and most important, put away the cell phone. I have seen many gas pump fires started by cell phones.
Make sure your propane monitor is good. I should know how they check it at the dealers but I do not. Also, RVs have their propane tanks near ground level and leaks in lines will leak downward because propane is much heavier than air. It's not like natural gas where gas can float and fill the RV. I would run it with gas to keep your meds cool.
Bob & Sue Rowan
Okeechobee, FL
2012 Coachmen Mirada 29DS (SOLD)
2015 Keystone Bullet Travel Trailer
2016 F-150 Lariat with Auto Trailer Backup
Dog = Morki (Yorkie-Maltese) - Zoe
Malabarbob is offline   Reply With Quote
Old 02-11-2014, 07:11 AM   #14
KyDan's Avatar
Igloo iceless 28 QT 12 volt cooler at Amazon is $90 with free shipping. It doesn't
say how many amps it draws but should not be a problem when the
engine is running.
Or run on LP like we do.
Happy Camping!
Dan & Rita D
2004 5.3L Silverado 1500 ext. cab 2WD
Blue Ox WD hitch, AirLift load levelers
2013-41, 2014-31, 2015-40, 2016-38
Old 02-11-2014, 07:46 AM   #15
Displaced2's Avatar
I run the 12 volt cooler and it works great. Keep it between cab seats for easy access while driving.
Displaced2 is offline   Reply With Quote
Old 02-11-2014, 08:22 AM   #16
bubbles's Avatar
Originally Posted by Mike & Molly View Post
I have medication that must stay cold before use.
Cooler / ice not always available on the road.
I am not comfortable cooling the refrigerator using propane while driving.
Planning on using the electric.
Question is - Is it running off the house batteries while driving and is the engine alternator enough to keep the batteries charged and operating the refrigerator while traveling.
Thanks for your help / advise.
2013 Sunseeker 3010DS
If you have the optional 4 door fridge I believe there is an engine ignition interlock that will not allow the fridge to operate (no spark start) for about 15 or 20 minutes after engine shutdown for fueling your MH. Also, if a propane line breakes that would shut down the propane bottle due to the regulator detecting an open gas flow. If you do not have the 4 door fridge I'm not sure if the standard fridge has the engine interlock. However; the open gas line protection is there. I think this is correct and therefore while driving with fridge operating on propane would not be hazardous. JMO.
Old 02-11-2014, 06:03 PM   #17
I could not imagine running without the fridge on. We turn the fridge on at least one day prior to departure and then fill it up when all is cold. I put my needed medicine in the fridge. This is our on the road home and why we have a fridge run on propane. On top of all that when we arrive the beer is cold!!
markangie24 is offline   Reply With Quote
Old 02-11-2014, 06:32 PM   #18
Taranwanderer's Avatar
How far and/or how long are you looking to drive before you get to your destination and can plug-in? Might I suggest the simple, low-tech approach: plug it in a day or two before you leave to get it nice and cold, and then take a gallon milk jug that you filled with water and froze in your house freezer, and place that in the fridge and close the door. A chunk of ice that big will keep your fridge cold for a considerably long time without the fridge being "on."
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)25
2014 Harley Davidson FLHX (XLR cargo)
2014 VW Jetta TDI (diesel sipper, camping support vehicle)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is online now   Reply With Quote
Old 02-11-2014, 06:42 PM   #19
We go 4-5 hours a day and sometimes have no schedule at all. That is a good idea for when we start and I will try that next time. Thanks for the info.
Old 02-11-2014, 06:42 PM   #20
Have towed with the frig on propane since 1976 and will continue to do so. If it were a problem with the thousands and thousands of people that tow with the frig on propane, you would see something on or in the news of rv explosions happening due to running the frig on propane while traveling.
