Old 05-25-2014, 06:16 PM   #31
we do not travel with our Refer on propane, I worry about fire. We are on the road for 6 to 7 hours and the Refer is still cold when we set up. It will not keep ice cream but the rest of the stuff is still cold. If you are not traveling over 7 or 8 hours it will keep cold. Any longer than that, weellll your are taking a chance.
higdonlg is offline   Reply With Quote
Old 05-25-2014, 06:32 PM   #32
Phat Phrog Stunt Crew
elind's Avatar
During out PDI the tech told us not to park on a incline with the frig on propane. He said the flame will burn out the side of the tube. Will the frig burn out or shut down by it self?
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 05-25-2014, 06:35 PM   #33
I have heard that too. I have never used propane so I don't worry about it. But take heed to what he tells you, they cost to much to replace. good camping
Old 05-25-2014, 10:30 PM   #34
Kaadk's Avatar
Originally Posted by Malabarbob View Post
While traveling unless the generator is on, the fridge works off both the battery and the propane. It does not draw much battery. It just need a level ground to stay running. If parked in a high-slope driveway, it will shut down, The key is watch for your auto light, if lit, you are OK. Yes, as an ex-fire chief, you MUST shut off the propane fridge flame while fueling and also NEVER use a cell phone near open fuel pump. You would not believe the explosions cause by cell phone ringers at pumps. We show the videos to new trainees.
Interesting. I watched the Mythbusters episode that showed cell phones completely harmless near gas pumps, as they're mostly solid state and don't spark so it's interesting you have actual videos. Now static discharge on the other hand they proved to be very harmful.
Either way, I don't use the phone and make sure to be well grounded before opening the tank or operating the pump.
There's no use crying over spilt milk, unless it's on your keyboard.
Kaadk is online now   Reply With Quote
Old 05-25-2014, 10:55 PM   #35
Would you please Post the Info for these (Training Videos) in relationship to the (Cell phone explosions at Gas pumps)! Youroo!!
Old 05-25-2014, 11:34 PM   #36
Infractee
I am pretty sure the cell phone myth was busted long ago. Recently had to take a refresher at work on hot pit refueling fighter aircraft (refueling the plane while it is running) and our instructor was the head fuel systems saftey guy for the entire USAF and he too mentioned that cell phones are classified as intrinsically safe, meaning they do not have near enough power to be able to cause an explosion in a fuel vapor saturated atmosphere. As was mentioned above, the real enemy is static electricity. Keep your self grounded to your vehicle and all will be well.
As for propane on, I like most here always leave it on while traveling and while refueling, my fridge vents are nowhere near where the gas is. The other fact is that gasoline vapors are heavier than air, they sink to the ground as soon as they escape containment, just as propane does. (This is why your LP detector is mounted just off the floor and not on the celing like a smoke detector)
Sent from my SAMSUNG-SGH-I337 using Forest River Forums mobile app
RhoZeta is offline   Reply With Quote
Old 05-26-2014, 02:58 AM   #37
Just a member
kandl's Avatar
Originally Posted by RhoZeta View Post
...cell phones are classified as intrinsically safe, meaning they do not have near enough power to be able to cause an explosion in a fuel vapor saturated atmosphere. As was mentioned above, the real enemy is static electricity. Keep your self grounded to your vehicle and all will be well.
Ditto - researched this issue at length about 10 yrs back as part of a flight safety team. There was a lot of noise being made about the safety of cell phones around aircraft or in hangars and especially around refueling ops. The noise was unfounded. The instances of supposed cell phone induced fires while refueling vehicles were in fact found to have causal relationships with other, well known, sources of ignition - esp static.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 05-26-2014, 06:58 AM   #38
Keeping the refrigerator level while operating has to do with the way the coolant travels through the tubing. If not level, it will get trapped in the bends in the tubing and eventually completely plug them. Then you buy a new refrigerator. This has nothing to do with the propane. It is the same whether on propane or electric. As long as the vehicle is moving, even up or down hills, it is not an issue. But when parked on a slope the problem can occur. Newer refrigerators are more tolerant than old ones, but still should be level when parked and operating.
As for traveling with propane on, this debate occurs here on a regular basis. Doubt if much said will change any minds. I travel with mine on. At gas stations I am much more concerned about the person next to me who re-enters their car after starting the pump. Static electricity when they get back out is a real danger.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 06-12-2014, 03:52 PM   #39
Since this is on a motorhome, how about using a 200 watt, 12 volt inverter to power the 120 volt for the refrigerator. The alternator will keep the coach batteries charged under the light load of the inverter. The refrigerator needs the 12 volt for the control circuit but the 120 volt plug for the refrigerator can be plugged into the inverter. There isn't a compressor so there won't be any motor starting load - something to trip the over-current of the inverter.
Just mount the inverter in the air space behind the refrigerator and run a fused 12 volt line to the inverter. As long as the refrigerator control panel detects 120 volt (be it from the inverter or shore power) it will not switch to propane - or just change the refrigerator switch to electric.
Bobby
bgilly is offline   Reply With Quote
refrigerator
