Old 06-11-2013, 09:58 AM   #31
Steve Jackson
sideout1961's Avatar
Originally Posted by OldCoot View Post
Really?
Really, the new generation water coolers have the safety feature. But I do like the idea of the single lever faucets.
2011 Dodge Ram 5.7 HEMI
2011 Flagstaff Classic 29bhss
sideout1961 is offline   Reply With Quote
Old 06-11-2013, 10:02 AM   #32
And the cost would be prohibitive IMO. I sure wouldn't want to have to press a button to get hot water in addition to turning a faucet. Love the KISS principal for everything.
Old 06-11-2013, 10:10 AM   #33
Steve Jackson
Understandable it was just a thought that popped into my head. It would be a pain.
Old 06-11-2013, 11:01 AM   #34
MotocrossCamper's Avatar
Originally Posted by bclemens View Post
Or replace the taps with a single lever faucet. That may help reduce the possibility of having "hot" on only.
You can also buy a faucet that has 2 valves under the sink to mix hot and cold how you want it, then up above is just one knob.
MotocrossCamper is offline   Reply With Quote
Old 06-11-2013, 11:08 AM   #35
Fulltime family RVer
That's what we have on our kitchen sink and I find I burn myself more with that one than anywhere else. It doesn't help that it's 100% opposite hot/vs/cold in the direction that you push/pull the temperature selector than our kitchen faucet at home.
With the bathroom sinks, daughter does turn the cold on and then add hot to it. The kitchen is a bit more obtuse.
Either way, I'm definitely going to look at playing with the winterization valves to adjust the heat down slightly. Bringing it more inline with my home water heater.
ependydad is online now   Reply With Quote
Old 06-11-2013, 11:24 AM   #36
That's what we have on our kitchen sink and I find I burn myself more with that one than anywhere else. It doesn't help that it's 100% opposite hot/vs/cold in the direction that you push/pull the temperature selector than our kitchen faucet at home...
You can just switch the hot & cold water lines underneath the sink and correct that. Doesn't even take a wrench.
Old 06-11-2013, 11:36 AM   #37
And sometimes the answer is painfully obvious. Thanks- hadn't thought about that. I'll climb under there next trip.
Old 06-11-2013, 03:52 PM   #38
Mine is so hot on electric that the outside pressure relief valves leaks. Thats how I noticed it. Switch to propane and it is fine.
MikeRP is offline   Reply With Quote
Old 06-11-2013, 03:54 PM   #39
That seems abnormal and something that should be looked at. I think there is a temperature gauge that shuts off the heating element. It sounds like there are separate ones for electric vs. propane. Could it be that your electric one is malfunctioning?
