Old 11-01-2015, 04:43 PM   #11
Originally Posted by Ford Idaho View Post
Just one!
Unbolt it from the wall, connect the two Pex ends with a 1/2 inch threaded coupler or more Pex and fittings.
https://www.google.com/?gws_rd=ssl#q=pex+shark+fittings
It just might save you a headache.
You can lead a horse to water, but....................
Unencumbered By The Thought Process
tande is offline   Reply With Quote
Old 11-01-2015, 05:32 PM   #12
BendOrLarry's Avatar
I installed a by pass, so I just turn one valve and the water filter is out of the system. It makes it simple to deal with when its time to winterize
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
BendOrLarry is offline   Reply With Quote
Old 11-01-2015, 06:04 PM   #13
Charles Firth's Avatar
To eliminate some problems, you can get a lot of the water out of the canister by turning on your 12 volt pump and opening a faucet , that should almost completely drain the canister. It should come off easier then and help eliminate spilling water.
Chuck " still in Va "
2012 3065w Windjammer
2012 f250 lariat Crew cab power stroke (of course )
Charles Firth is offline   Reply With Quote
Old 11-01-2015, 07:02 PM   #14
Garrette's Avatar
When I took mine off for the first time I wanted to meet the assemblier. Way too tight.
When you finally get it off, put the canister back on, use a little Vaseline on the oring and threads. Put it on hand tight. Do not over tighten. I keep extra orings handy, just in case. I also leave it off in the winter. If there is any water trapped in the threads, may freeze and crack the canister at the thread. If you need the wrench to tighten, to stop leakage, replace the oring.
Garrette is offline   Reply With Quote
Old 11-01-2015, 07:35 PM   #15
Georgia Frog Rally 2018
aceinspp's Avatar
The one that came with my new camper is a little different as you really do not need the wrench and then when reinstalling you hand tighten. Something new I guess. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 11-01-2015, 08:01 PM   #16
Love My Sunseeker
DXSMac's Avatar
I have the same problem. Last time I changed the filter, I got a man to get it off, then I put it on "hand tight" (MY hand). The next time I tried to get it off, IT WAS TIGHT AGAIN!
I'm going to try the "open faucet" trick.
JJ only, my cat went to Rainbow Bridge July 2015
I love my Sunseeker, when I'm on a trip I don't wanna go home!!!"
Total days camping each year: AS MUCH AS POSSIBLE!
DXSMac is offline   Reply With Quote
Old 11-01-2015, 08:22 PM   #17
Agree with almost everything you have said except the part about Vaseline on the o-ring, should use silicone grease instead, Vaseline can cause the rubber to swell or breakdown over time.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 11-02-2015, 07:31 AM   #18
PhoneDude 8289's Avatar
X2
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 11-03-2015, 10:49 AM   #19
Mike968's Avatar
Removing water filter
Do not use any petroleum product on rubber or Viton o-rings, they will swell and deform over time causing leaks and heartache. Also, Vaseline is not food safe.
Silicon grease is the way to go; You can pick up a tube at Home Depot or local pool supply store.
Mike968 is offline   Reply With Quote
Old 11-03-2015, 11:03 AM   #20
A32Deuce's Avatar
Seems to be several types of water filters in use on RVs. Looks like the ones with a o-ring seal on the threads tend to break rather easily. Mine looks to be thicker and seals when screwed all the way in. Only time mine broke, I was in hospital, had not drained, got a cold snap and it froze and broke at the threads. Had the heat on low, ran out of propane and DW could not drive RV to get refill.
A32Deuce is offline   Reply With Quote
water, water filter
