Old 11-03-2015, 12:01 PM   #21
JimOneil43's Avatar
I have read several posts where people have just eliminated that filter and use a disposable one on the fresh water input outside. Seems to be a lot of problems with the factory installed one.
Retired and loving it...Can't wait to get back on the road!
2017 Forester 3051S ("Farley")
Born April 18, 2016
Toad: 2014 Honda CR-V AWD
GO DUCKS !!
Jim & Diana (and 3 cats)
JimOneil43 is offline   Reply With Quote
Old 11-03-2015, 05:54 PM   #22
I have had no problems with the factory filter and like the fact that it provides filtration for all water (in tank or shore), with no fuss or muss. I have winterized each year with air and anti freeze. I remove the filter canister, remove the filter, then pump AF. It fills the canister and pumps through the system. I dry the threads fully on the canister and have had no problems. A new filter cartridge in the spring and we are ready for another season.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 11-03-2015, 06:06 PM   #23
B and B's Avatar
Same here. I do use the tank more than hose so filtering that water is important to me as well.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 11-03-2015, 06:53 PM   #24
Boso's Avatar
Vaseline might not be food safe but that is what was used before Chapstick was invented maybe you are little young for that
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 11-03-2015, 07:16 PM   #25
schrederman's Avatar
I removed mine and have a stainless bracket on the side of the trailer for it to hang on. I always use city water so I am not worried about the water in the tank or pump. I'll put it all back stock when I sell the trailer.
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
Old 11-03-2015, 07:43 PM   #26
rattleNsmoke's Avatar
Ayup...now we're showing our age. Ohhh how I remember Mom smearing that vasoline..
Personally, I don't use any O-ring lube. Keep the ring clean and make sure the cartridge is perfectly aligned with the down tube and screw it on until it makes contact. Go slow, take your time. Once it's on, give a gentle twist to tighten and Voila! The cartridge should be leak free.
rattleNsmoke is offline   Reply With Quote
Old 11-03-2015, 07:46 PM   #27
Boso's Avatar
X2 rattleNSmoke
Old 11-03-2015, 09:07 PM   #28
No vaseline
I had similar filters for my sticks and bricks home. It is important to always relieve the pressure by turning turning on faucets and let system drain without the pump running. Always use a small amount of FOOD SAFE SILICONE on the "O" ring and the threads. A little goes a long way. Make sure the silicone lube is FOOD SAFE. And yes I have eaten vicks which is vaseline. Might be ok to ingest but it will interact with the rubber washers in the valves of the RV and you will have to replace them.
I didn't know the pump will drain the filter sump, got to try this, I hate juggling these canisters full of water.
Harry & Alice
Furkid Spruce
2014 Sunseeker 2650s
Friend of Bill and Lois
since May 30, 1975
Happywanderer is offline   Reply With Quote
Old 11-05-2015, 09:31 PM   #29
MNtraveler's Avatar
Removing water filter
This has its advantages but then you will not have a filter on water coming OUT of the fresh water tank. Any dirt, sand or (worse) bacteria in the tank or its line will be pumped right into the coach lines.
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 11-05-2015, 09:54 PM   #30
Boso's Avatar
I don't have any problems with the filter I just blo lines drain hot water heater pump freshwater tank out the low point remove filter install cover back on if filter still clean put In ziplock bag until spring pink in traps little in black and gray tanks winterized
water, water filter
