Old 11-06-2015, 11:00 PM   #31
Mike968's Avatar
Originally Posted by Boso View Post
I don't have any problems with the filter I just blo lines drain hot water heater pump freshwater tank out the low point remove filter install cover back on if filter still clean put In ziplock bag until spring pink in traps little in black and gray tanks winterized
Are you so old that you learned to write before commas were invented too?! Haha!
Mike968 is offline   Reply With Quote
Old 11-06-2015, 11:57 PM   #32
Fulltime family RVer
Are you so uncooth that your momma never taught you that if you have nothing nice to say, don't say it at all? Sheesh!
Old 11-07-2015, 12:50 PM   #33
MNtraveler's Avatar
You threw the first age hit back at #24 and his was intended as humorous "haha" it says. Let's all lighten up and get back to RVing? 😩😅
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 11-07-2015, 03:46 PM   #34
Love My Sunseeker
DXSMac's Avatar
Whoever gave that tip about "turn on the water pump" and run water to drain it out of the filter cannister, IT WORKED!
I got my water filter cannister off EASY! THANK YOU!
JJ only, my cat went to Rainbow Bridge July 2015
I love my Sunseeker, when I'm on a trip I don't wanna go home!!!"
Total days camping each year: AS MUCH AS POSSIBLE!
DXSMac is offline   Reply With Quote
Old 11-07-2015, 03:53 PM   #35
Ever hear about the kettle calling the pot "black bottom"?
Old 11-07-2015, 03:57 PM   #36
Originally Posted by rattleNsmoke View Post
Ayup...now we're showing our age. Ohhh how I remember Mom smearing that vasoline..
Personally, I don't use any O-ring lube. Keep the ring clean and make sure the cartridge is perfectly aligned with the down tube and screw it on until it makes contact. Go slow, take your time. Once it's on, give a gentle twist to tighten and Voila! The cartridge should be leak free.
Better to use just a little Danco Silicone lube on the O ring. If nothing is used on the O ring, they seem to like to stick to the surfaces they touch. VOE!
Old 11-07-2015, 04:08 PM   #37
BendOrLarry's Avatar
Am I the only one here that has put a bypass kit on their water filter canister? It's the same kit as a hot water tank bypass and all you have to do is turn the lever remove canister dump water and winterize. No antifreeze gets to the canister and then in the spring, put the filter back in and turn the lever and you are back in business.
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
BendOrLarry is offline   Reply With Quote
Old 11-07-2015, 04:24 PM   #38
Oakman's Avatar
I just don't see a need to do that. All you are doing is saving about a quart of anti-freeze. The stuff isn't that expensive to worry about a quart.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 11-07-2015, 04:46 PM   #39
Funny that you'd throw your hat into this ring. Welcome, Mr. Kettle.
Old 11-07-2015, 04:53 PM   #40
dan-nickie's Avatar
Originally Posted by RvBill3 View Post
I dry the threads fully on the canister and have had no problems.
2012 Forest River Sunseeker 2300 Chevy
I believe this is the simple secret that will cure all of the problems people have with the canisters blowing off.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
water, water filter
