Old 11-10-2015, 08:11 AM   #51
dan-nickie's Avatar
Originally Posted by OldCoot View Post
It is the stock Forest River filter canister that came in the 5er new. I just found a filter @ Lowes that fit the same as what the factory put in it.
So can you share that canister part number you got at Lowes? I know a lot of people are looking for replacements.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 11-10-2015, 08:31 AM   #52
MNtraveler's Avatar
Originally Posted by trdutch View Post
Not to open a new can of worms but mine was surrounded by a lot of insulation foam and I had to carefully cut enough away to remove and reinstall
In other words first time removal was impossible and I couldn't figure out why until further inspection found a mound of foam under, toward the back of canister that was pinning it to the housing
I had that too. But nothing a jackknife couldn't clear out. And I'm happy to have lots of insulation and crack sealant! Once that was cleared a bit, I was able to remove full filter canisters twice without spilling a drop. Just use two hands, lower straight down and take straight out. The location under the bed is very not optimal but apparently that's where it had to be...
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 11-10-2015, 11:38 AM   #53
Here are some pictures of the filter I use. I have a new one installed and have 5 spares I carry in the basement. I will change filters after I get home from 3+ months in FL.
ID:	94022   Click image for larger version
ID:	94023   Click image for larger version
ID:	94024   Click image for larger version
ID:	94025   Click image for larger version
Old 11-10-2015, 12:39 PM   #54
I have been reading the posts and I have a 2015 Leprechaun and can anybody tell me where the water filter is located.Thks in advance.
hardoiler is offline   Reply With Quote
Old 11-14-2015, 11:32 PM   #55
Originally Posted by BendOrLarry View Post
I installed a by pass, so I just turn one valve and the water filter is out of the system. It makes it simple to deal with when its time to winterize
Installed a bypass on my 2011 Sunseeker 2300. Horrible job because the idiots at Forest River did not leave sufficient space to the left of the water pump for the bypass valve. It's bad enough to deal with a cheapskate company that won't provide a bypass, but having to redo the piping is adding insult to injury. Had to cut pipe and shift water pump to the right. Took the opportunity to remove the water filter. Another horrible project due to lack of clearance above top screws.
davegood is offline   Reply With Quote
water, water filter
