10-30-2015, 02:49 PM
Removing water filter
Trying to remove my water filter for winter for the first time, and I'm not able to get it off -- I mean, it won't budge. I don't want to put too much pressure on it and crack it, and I'm not 100% sure I'm even trying to turn it the right way. It sits vertically, so I'm twisting it what would be counter-clockwise.
Any suggestions?
10-30-2015, 02:52 PM
righty tighty - lefty loosey. Are you using your filter wrench?
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
10-30-2015, 02:54 PM
Nope...didn't even know there was such a thing. Obviously, I"m a newbie Guess I'll have to figure out where to get one
10-30-2015, 02:55 PM
Make sure that you have opened several faucets and removed ALL pressure from the lines. Put a slight upward pressure on the sump as you turn. As you look at it from the side, you should be turning toward the left.
2016 Berkshire XLT 43a
10-30-2015, 02:59 PM
And that's why I love this forum. Bingo, something that hadn't occurred to me -- relieving the pressure by opening faucets. Came right off. Thanks!
10-30-2015, 03:02 PM
Glad you got it loose. Since you have a filter there should be a water filter wrench too. It would look something like this.
Bob and Joyce
ATU Local 788
10-30-2015, 03:24 PM
Lol well now that you mention it I do remember seeing that in one of my cabinets inside. Now I'll know for next time
10-30-2015, 03:59 PM
Any suggestions?
Just one!
Unbolt it from the wall, connect the two Pex ends with a 1/2 inch threaded coupler or more Pex and fittings.
https://www.google.com/?gws_rd=ssl#q=pex+shark+fittings
It just might save you a headache.
10-30-2015, 04:20 PM
Filters are weak
Originally Posted by Ford Idaho
x2:
It will fail and cause major flood
Best,
Grn_Mtns
____________________________________
2018 8329 SS Rockwood /260watts solar
11-01-2015, 05:16 PM
Love My Sunseeker
OH! I have had the same problem trying to get my filter cannister off. I didn't even think of opening the faucets and relieving the pressure. I need to change my filter right now. I always have trouble getting that thing off with the filter wrench. Even MEN I have asked have had problems.
JJ only, my cat went to Rainbow Bridge July 2015
I love my Sunseeker, when I'm on a trip I don't wanna go home!!!"
Total days camping each year: AS MUCH AS POSSIBLE!
11-01-2015, 05:43 PM
You can lead a horse to water, but....................
Unencumbered By The Thought Process
11-01-2015, 06:32 PM
I installed a by pass, so I just turn one valve and the water filter is out of the system. It makes it simple to deal with when its time to winterize
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
11-01-2015, 07:04 PM
To eliminate some problems, you can get a lot of the water out of the canister by turning on your 12 volt pump and opening a faucet , that should almost completely drain the canister. It should come off easier then and help eliminate spilling water.
Chuck " still in Va "
2012 3065w Windjammer
2012 f250 lariat Crew cab power stroke (of course )
11-01-2015, 08:02 PM
When I took mine off for the first time I wanted to meet the assemblier. Way too tight.
When you finally get it off, put the canister back on, use a little Vaseline on the oring and threads. Put it on hand tight. Do not over tighten. I keep extra orings handy, just in case. I also leave it off in the winter. If there is any water trapped in the threads, may freeze and crack the canister at the thread. If you need the wrench to tighten, to stop leakage, replace the oring.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
11-01-2015, 08:35 PM
Georgia Rally Coordinator
The one that came with my new camper is a little different as you really do not need the wrench and then when reinstalling you hand tighten. Something new I guess. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
11-01-2015, 09:01 PM
Love My Sunseeker
I have the same problem. Last time I changed the filter, I got a man to get it off, then I put it on "hand tight" (MY hand). The next time I tried to get it off, IT WAS TIGHT AGAIN!
I'm going to try the "open faucet" trick.
11-01-2015, 09:22 PM
Agree with almost everything you have said except the part about Vaseline on the o-ring, should use silicone grease instead, Vaseline can cause the rubber to swell or breakdown over time.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
11-02-2015, 08:31 AM
X2
Joe & Beverly
2014 Ram 2500 CTD, CC, SB
2014 8289WS lifted
11-03-2015, 11:49 AM
Do not use any petroleum product on rubber or Viton o-rings, they will swell and deform over time causing leaks and heartache. Also, Vaseline is not food safe.
Silicon grease is the way to go; You can pick up a tube at Home Depot or local pool supply store.
11-03-2015, 12:03 PM
Seems to be several types of water filters in use on RVs. Looks like the ones with a o-ring seal on the threads tend to break rather easily. Mine looks to be thicker and seals when screwed all the way in. Only time mine broke, I was in hospital, had not drained, got a cold snap and it froze and broke at the threads. Had the heat on low, ran out of propane and DW could not drive RV to get refill.
