Old 11-22-2013, 07:40 PM   #11
Garrette's Avatar
Originally Posted by TomG View Post
I removed the sofa and replaced it with 2 small LazyBoy wall hugger recliners. They fit tight but nicely on the raised slide. I secured them and also screwed a piece of angle iron on the front edge of the raised slide in front of the chairs to prevent the chairs from moving forward off the slide. The wooden chair legs screwed nicely into the screws in the angle iron to further secure the chairs. I also moved the TV and placed it on a wall mount directly above the door so it was directly in front of the chairs. The wiring was just long enough.
Please post pictures of your upgrade.
Garrette is offline   Reply With Quote
Old 11-23-2013, 11:32 PM   #12
Garrette's Avatar
these are Tom's pictures of his couch to recliner Mod and his TV relocation.
ID:	42994   Click image for larger version
Old 01-21-2014, 02:00 PM   #13
We have a 2300 SunSeeker and I wanted to replace the U shaped dinette with a love seat, wall hugger recliner. I noticed that on one of the 5th wheels that FR manufactures the love seat, wall hugger was manufactured by Lane furniture. Has any removed a U shaped dinette and how difficult is it? I did notice that the seat belt bolts going through the floor had nuts attached under the coach. Some were accessible and a couple were inside the spray foam insulation. Also should I be concerned about weight distribution? Thanks for a response!
lexstone is offline   Reply With Quote
Old 01-23-2014, 10:55 PM   #14
I have a 2013 3010DS and we opted to replace the sofa with a Lazy Boy, Love Seat, double recliner, Carter model. The opening on the slide is 66" and the love seat recliner is 65" wide. Fits nice. I was able to secure the love seat to the slide platform using sheet metal screws thru the metal frame. The love seat had a 7" to 8 " overhang on the front of the slide platform and I fabricated a 2"x4" brace with 3 rollers attached and works great with the movement of the slide.
bobrich1 is offline   Reply With Quote
replacement
