Old 10-01-2018, 12:55 PM   #1
Hoglou's Avatar
replacement grab handle
I replaced the yellowing exterior grad handle. The pic shows the part number. 42$ amoz purchase. This one has the handle light but I will cut those wires. Sourcing this was a tad difficult. Screws not included.
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 10-07-2018, 09:34 AM   #2
Garrette's Avatar
I painted mine with the krylon plastic coat along with the outside radio cover. Took several light coats plus drying time between coats. 1 year in, so far, so good. I am going to mask off the termination trim ends and try that this fall.
Thanks for the info.
Garrette is offline   Reply With Quote
Old 10-07-2018, 01:36 PM   #3
Hoglou's Avatar
mellow yellow, dont think so
The grab handle and the rub rail ends are the only items that went yellow. Sourced the handle, but not sure the end caps are worth the work. Just finished press wash the perm residence and out of steam for the weekend.
Spray painting them may be the solution this spring.
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
replacement
