Old 03-31-2019, 08:52 AM   #1
Replacing 32" 12 volt Insignia
Our 32" 12-volt Insignia TV has failed and replacement options seem few for a 12 volt. Any recommendations?
Thanks for any advice!Click image for larger version
withoutoneplea is offline   Reply With Quote
Old 03-31-2019, 08:57 AM   #2
PPST Wannabe
kenandterry's Avatar
Maybe itís just me.....
But if youíre interested in a television that works on 12 volts.....seems to me you're more interested in a more primitive style of camping.
Getting away from it all and television in the same sentence just doesnít seem right to me.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is online now   Reply With Quote
Old 03-31-2019, 09:24 AM   #3
Good point. We have two televisions in our FR 2400R MBS. The one in the living room is 12 volt which is nice to catch up with the news or weather while traveling or boondocking and not connected at a site.
Thanks you.
Old 03-31-2019, 02:53 PM   #4
Senior Members
Butch & Lena's Avatar
Thanks for any advice!Attachment 200327
We have two 32" 12 volt Jensen TVs and have had no problems with them for the past 5 years.
2015 3010DS Sunseeker
2010 Jeep Wrangler Unlimited
Butch & Lena is offline   Reply With Quote
Old 03-31-2019, 03:05 PM   #5
Glad to hear that. That's the kind of reliability I'm looking for. Thank you.
Old 03-31-2019, 04:25 PM   #6
CincyGus's Avatar
If you have a decent battery bank, might consider just getting a regular 110v tv and a 1000w inverter ($110) to run it.
https://www.walmart.com/ip/12V-1000-Watt-Pure-Sine-Wave-AC-Power-Inverter-with-USB-Port/317692437?wmlspartner=wlpa&selectedSellerId=1082&a did=22222222227068288252&wmlspartner=wmtlabs&wl0=& wl1=g&wl2=c&wl3=174505880807&wl4=aud-482018033502la-280558786033&wl5=9015733&wl6=&wl7=&wl8=&wl9=pla&wl 10=112561763&wl11=online&wl12=317692437&wl13=&veh= sem&gclid=Cj0KCQjwyoHlBRCNARIsAFjKJ6DY-tbwTpJzC5G5YQP3M1o8Z4dE8bMSGvkigysftTBhrGAfLkfOYJg aAjqPEALw_wcB
Depending on the size 12V tv your looking at, you can likely buy both the same size 110v and the inverter for the same price, then have the inverter that can run something else if the need arises.
2015 GMC 2500K Denali, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart
CincyGus is offline   Reply With Quote
Old 03-31-2019, 05:39 PM   #7
https://www.walmart.com/ip/12V-1000-...gaAjqPEALw_wcB
That's what we did when our 12v TV failed, have not used the inverter yet, but nice to know we can if needed. Also, we can use the inverter for other low current things as well if we are ever boondocking or stuck in the Walmart parking lot.
2017 Forester 2861DS
towing 2015 Jeep Rubicon
fobagbob is offline   Reply With Quote
Old 03-31-2019, 05:49 PM   #8
2012 Solera
300 watt pure sine wave inverters are getting pretty cheap (<$50) and should run a 32 inch modern tv no problem -
https://www.amazon.com/BELTTT-300W-P...ct_top?ie=UTF8
Smaller inverters have (in general) less idle current than larger ones - one comment on the Amazon site says this one draws ~0.4 amps unloaded.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 03-31-2019, 06:52 PM   #9
llr
Some of the smaller TV's use a power adapter, some with 12 volt output then you can just buy or make an adapter.
You will need to check in stores as this type of information is not generally listed.
TT 2017 Flagstaff 831CLBSS Classic Ultra lite
TV 2014 Silverado 2500 HD
llr is offline   Reply With Quote
Old 03-31-2019, 08:30 PM   #10
Replacing 32&quot; 12 volt Insignia
I bought a used 32Ē 12 volt Insignia off of eBay for $40 to replace the Jensen that failed in my 2015 2300.
Some of the newer TVs use a 120v ac to 19.5 dc adapter. You can then buy a 12volt DC to 18.5 DC adapter. Iíll most likely go this route next time.
2015 Sunseeker 2300 Chevy
swuebbels is offline   Reply With Quote
12 volt
