Old 11-26-2014, 10:43 AM   #21
GM
bclemens's Avatar
Nope, once we went to two batteries standard, we never looked back.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 11-26-2014, 12:07 PM   #22
Canadian Member
itat's Avatar
Originally Posted by scoto View Post
Thanks for the response. If I install 2 12 volt batteries do I have to do anything to the electrical setup. Charger/ inverter etc. Thanks
Nope. Just hook them up in parallel (+ to + and - to -).
Old 11-26-2014, 12:10 PM   #23
I feel ripped off then,mine only had the one battery!! ( which I have already replaced with better battery ) Like I said, not hard to install another if needed, right now I can use the extra weight space for other things
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 11-26-2014, 12:15 PM   #24
Flybob's Avatar
Did you actually lighten the beer load or just transfer it to a different container?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-26-2014, 12:27 PM   #25
HAHA, it went to the spare tire, ( the one around my waist )
2014 Forester 3051s
2012 Sonic toad
Old 11-26-2014, 08:04 PM   #26
camaraderie's Avatar
You don't HAVE to do anything BUT it will take longer to charge 2 batteries than one with the same charger. That is NOT a problem but if you want it to go faster with dual 12v batts...you should sized the charger at somewhere around 50 amps. Minimum charger size for dual 12V batts is around 20amps which is prolly less than you have now.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is online now   Reply With Quote
Old 11-26-2014, 08:10 PM   #27
GM
bclemens's Avatar
All of our units have a 60 amp converter. We don'r have a small converter for single battery and larger for 2 batteries. Same converter for everything.
Old 11-26-2014, 08:38 PM   #28
That's ideal then. Thanks for that info.
________
Cam
Old 11-29-2014, 07:15 PM   #29
Thanks everyone for your replies. One more question. Sealed or not sealed batteries?
scoto is offline   Reply With Quote
Old 11-29-2014, 07:34 PM   #30
I went with 2 Trojan wet cells.
Work great. Last great.
Kevin & Judy is online now   Reply With Quote
12 volt, 3170, battery
