Old 11-24-2014, 10:49 AM   #1
Replacing single 12 volt battery 3170ds
I need to replace the single 12 volt Battery, thinking of 2 6 volt deep cycle batteries. Do I need to change the inverter or any other component? How to install cables? Any suggestions on batteries. Thanks
scoto is offline   Reply With Quote
Old 11-24-2014, 11:19 AM   #2
offroad's Avatar
No just wire the two 6V batteries in series, they are just like a 12V battery then.
http://www.marxrv.com/12volt/12volt.htm
2017 Open Range - Light 297RLS, BX1 Gooseneck
2014 Ram 2500 4x4 CCSB 6.7L 68RFE
offroad is offline   Reply With Quote
Old 11-24-2014, 11:26 AM   #3
As long as you have the space requirements and proper venting no additional modifications are required other than hooking up the two batteries in series. Hookup is positive to negative on the batteries (with proper size cable between batteries) and the trailer cable is positive cable to the remaining positive post on the battery and negative cable (trailer) to the remaining negative post on the battery. I use 2 golf cart 6 Volt batteries.
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 11-24-2014, 12:12 PM   #4
Is a person better served using 2 6volt batteries vs 1 12 volt?
VT Skier is offline   Reply With Quote
Old 11-24-2014, 01:28 PM   #5
Witch Doctor's Avatar
You will gain amp hrs if you are a boondocker or not. If you are teather type person at a CG with power, just use a 12v. Cheaper, depends on how you use your trailer.
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-24-2014, 01:40 PM   #6
mud yapster's Avatar
I have 2 12v batteries paralleled just because I didn't want to buy 2 new batteries, already had the battery the rig came with. Been working great for me. Even though I haven't really stressed my 2 battery set up I have room to add 2 more if needed for a 4 bank system.
OP, a two battery set up of 6v or 12v will always serve your needs better. Cons- a 2, 6v battery set up if one battery fails your on a pickle without power. Just something to think about.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 11-24-2014, 01:48 PM   #7
i Have two 12 volt, plenty of power for my camping type. Last time I boondock was in the Army. You make a good point if a 6 volt gets a bad cell your just screwed. But everyone is different...
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-24-2014, 02:07 PM   #8
LOL my dad and I boondocked everywhere and anywhere while I grew up as a Army Brat. Caves, tents, Army trucks, slept in a tank once, helicopter once, you name it we loved to camp anywhere and everywhere. The good old days we always had a blast!!!
Old 11-24-2014, 07:36 PM   #9
I'm very weight conscious and almost never camp without hookups so I removed my second 12v battery. Unless you boondock I would stay with one battery. I needed a battery in another camper so it didn't go to waste.
ATVer is offline   Reply With Quote
Old 11-24-2014, 07:53 PM   #10
Good idea for some but I'm already towing 16,000 lbs. so another 70# battery doesn't hurt me and on the way back from camping I've lightened the beer load so I'm saving fuel. LOL
12 volt, 3170, battery
