Old 10-28-2013, 06:10 PM   #11
Noise Under Carriage
I do have the Big Foot system. They do leak off occasionally but a buzzer comes on to let you know to raise them. Do you think a jack would make some blabbering vibration noise by just shutting the door?
jtrippy is offline   Reply With Quote
Old 10-28-2013, 06:23 PM   #12
I mention it as if there is a short. There are two solenoids at each hydraulic station. If there is a short everything "normal" is out the door. I'm thinking of items that would make noise with the engine off and nothing else in the coach running.
bgilly is offline   Reply With Quote
Old 10-29-2013, 07:41 AM   #13
MotocrossCamper's Avatar
Does the new Ford chassis have anti-lock brakes? A good friend just had to have his pump that controls the anti lock brakes on his ford pickup changed. It malfunctioned and would randomly start running even when it was parked and turned off. If you have one you should be able to follow the brake lines down the frame rail and you will come across a pump that the brake lines run into. You can unplug the wire harness and see if it stops the problem.
When it ran while he was driving it was loud enough to hear and feel it in the cab.
MotocrossCamper is offline   Reply With Quote
Old 10-29-2013, 03:24 PM   #14
I don't know. I need to check that out. Thanks.
Old 10-29-2013, 03:28 PM   #15
I wish the factory rep would throw his two cents in?
Old 10-29-2013, 03:40 PM   #16
If you are referring to Brian; he has read the topic and commented on posts he had clear information on, otherwise he is like the rest of us in trying to diagnose something strictly on a narrative. Just one of those that you have to be with the coach to properly diagnose.
If your dealer doesn't have a clue (the ones that are able to crawl all over the coach) - those of us on the other end of the World Wide Web are surly in the dark.
JMO,
Bobby
Old 10-29-2013, 03:46 PM   #17
Got it.....Just thought they may have had a slant on the subject since they are the people who built it!
Old 10-29-2013, 03:49 PM   #18
An understandable assumption but I believe if he had something to say to check he would have by now.
Old 10-29-2013, 03:52 PM   #19
fonzie's Avatar
Could it be your water pump cycling?
Fonzie
Old 10-29-2013, 06:04 PM   #20
Yeah, I think your right. Maybe he is checking on it for us. Thanks for your heip.
I am going to try to make a video and post it on you tube. Maybe that would give you a better understanding.
