Old 11-03-2012, 09:46 AM   #1
Roof Sealing
We just completed our first trip in our new Sunseeker. All went well, but had some problems getting the TV antenna to rotate. Climbing on the roof to investigate, I found that several areas contained puddles (it had rained the night before) mostly between the roof and the side attach seals. It seems an area just asking for leaks. Has anyone else had this experience or leaks?
Geri
Geri is offline   Reply With Quote
Old 11-03-2012, 10:19 AM   #2
I have a 09' Rockwood that does the same thing. No problems at all. Every year just check the seals for cracking and seal it with proper rubber roof caulk if needed. (I presume you have rubber roof?)
pwrstroke2012 is offline   Reply With Quote
Old 11-03-2012, 12:29 PM   #3
GM
bclemens's Avatar
Sunseeker is Fiberglass starting in about 2009ish.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
Old 11-03-2012, 12:41 PM   #4
Roof Leaks
Not rubber. Might be fiberglass but appears to be metal. Thanks for assurances that your's doesn't leak w/ just yearly maintenance.
geri
Old 11-03-2012, 01:29 PM   #5
Our TT roof is fiberglass and we have similar pooling near skylight over the shower in corner of TT. I add 501 self leveling lap sealer to ensure no leaks. So far no leaks.
Roy & Jean
2010 Rockwood mini Lite ETC 181
2002 Toyota Tundra 4.7l 4x4
Prodigy P3, E2 WDH
rschoono289 is offline   Reply With Quote
Old 11-04-2012, 06:04 AM   #6
Self Leveling Sealant
A great idea. Didn't know that there was a self-leveling sealant, but seems the perfect answer for puddle spots - well, maybe less than perfect; the better way would have been to build it without puddle spots.
Geri
