Old 10-04-2015, 12:07 PM   #11
OP here. I found a similar part at the local Camping World for $12. It's a knob instead of a crank arm. I took what I had apart, didn't measure the pieces, but this looks close. The only thing I can't figure out is where the little aluminum shim thing (by the knob in the picture) goes.
Name:	ImageUploadedByForest River Forums1443978464.104247.jpg
All previous rigs below are sold - waiting until the kids graduate to the buy the next one!
'13 Forest River Sunseeker 3100 Class C
'04 Fleetwood Sedona Pop Up / Reese Mini 350 / Prodigy / BAL
'94 Coleman Cedar Pop Up
paulmlac is offline   Reply With Quote
Old 10-04-2015, 12:21 PM   #12
VinceU's Avatar
Attachment 90617
Tensioner to keep knob from turning? Also ran Jensen and Elixir besides Ventline supply the vents
Old 10-04-2015, 01:33 PM   #13
OP here. No luck. The new part was a little different size and won't work. Now to try to find the right size. I'll check the Internet for the other names you mentioned. I don't think a new rivet or sheet metal screw would work either (I tried clamping the mechanism tight and it still doesn't work right).
Old 10-04-2015, 01:41 PM   #14
So remove it and see what is wrong with it.
Old 10-04-2015, 01:49 PM   #15
Cyber Phrenologist
Radio's Avatar
The arm has a gearbox on one end and a "round thing like a wheel" on the other. The "wheel" goes through the slot (or track) on the lid and the shim thing clips onto the wheel to hold it in the track.
Inspect your lid while you are doing this repair. A new lid is under $20 and while you are doing all of this you might as well change the lid, as they do not last long in UV light.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 10-04-2015, 06:48 PM   #16
VinceU's Avatar
I think CW carries all three makes. Otherwise you can try PPL in Texas, they have enormous stock/availability. Easiest to ID by the hinge design.
roo, roof, vent
