Old 09-28-2018, 07:34 AM   #1
Rough roads are shaking my RV apart!
I have had an issue with my microwave for a couple seasons now. The face plate that covers the cubby it rides in comes loose on the bottom. It has now broken the face plate in the top right corner. I think the mfg put the face plate to high and it is holding the weight of the microwave rather than just being a cover.
After my recent trip to Wisconsin and over the rough roads of Northern Indiana, Illinois and Wisconsin I have several other issues. The bathroom mirror, frame and all, popped off and hit the floor. Fortunately it didn't brake or leave a mark on the counter top or mirror. So I will have to find a way to re-hang it on the paper thin walls.
Also, the latch for the bathroom cabinet door under the sink has come loose and now the cabinet door won't latch and stay closed. Simple fix, I just need to put a new nail or screw in the latch.
But dang, how flimsy are these things? I know they aren't the stoutest built vehicles on the road, but I feel like many more rough roads like that and nothing will be left hanging on the walls.
2014 Sunseeker 2860DS
gmacklem is offline   Reply With Quote
Old 09-28-2018, 07:48 AM   #2
Shredder's Avatar
I agree there are some really bad roads out there. Almost lost my false teeth on them.. J/K..
I try to stay on top of all the things in the RV after I reach my destination I do a quick sweep and tighten anything that needs to be tightened and fix anything that needs to be fixed asap.
2 years now and everything it still tight and smells brand new.. just stay on top of the little things and don't let them build up. It will make your experience that much better.
Bob
2013 Forest River Sunseeker 3010DS
Shredder is offline   Reply With Quote
Old 09-28-2018, 08:07 AM   #3
jeff64's Avatar
That I 43 from the Il. state line to G.B. is a rough bugger. Just came back from Door County a couple days ago. Hasn't got appreciably better over the past couple years. Major construction from Kenosha through Racine to Milwaukee, down to 2 lanes either way.
Lost the cable cover that slides in from the bottom on my Dometic 9100 series awning from the vibration. $30 for a new kit and a couple dabs of silicone at the bottom and back in business
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 09-28-2018, 09:47 AM   #4
Total Loss's Avatar
I hit some crap on my last trip and I thought my dash panel was going to fly off.
Gotta keep up with loose stuff constantly.
"If you are going through hell..keep going"
W. Churchill
Total Loss is offline   Reply With Quote
Old 09-28-2018, 09:50 AM   #5
TomAR's Avatar
My TP unrolled onto the floor while driving on PA roads. Thought my DW adopted a dog and didn't tell me.
2018 Sunseeker 2400R MBS (w/dinette)
TomAR is offline   Reply With Quote
Old 09-28-2018, 11:01 AM   #6
Enjoying Life
Going through St. Louis, we went through an area of I55 that made us think we were going to lose it all. When we got to the camp that night we found our shower door had been knocked off. Luckily it did not break.
2019 Rockwood 2608BSD 2019 F250 4x4 6.2
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!” - Hunter S. Thompson, The Proud Highway: Saga of a Desperate Southern Gentleman, 1955-1967
TeachTexas is offline   Reply With Quote
Old 09-28-2018, 12:01 PM   #7
I noted the same issue on our 2000 Four Winds unit when we purchased it used in 2010. The faceplate was supporting the entire weight of the µWave.
I removed the assembly and installed braces/boards in the bottom of the compartment for the µWave to set on, complete with notches so it would not slide out of the hole unless it was lifted a bit. I repaired the faceplace and reinstall the assembly. It never moved afterward.
This is part and parcel to owning a motorhome, unfortunately. They are poorly engineered and rapidly assembled.
It gives you room to flex your creative muscles - go create/correct!!!!
2016 2250LE/Chevy
Formerly: 2000 Four Winds 26Q/Ford, '96 Kit Sportsmaster 22' 5th wheel, '91 Sunlite truck camper, Wildernest flip-top canopy
brucemc is offline   Reply With Quote
Old 09-28-2018, 01:09 PM   #8
Ree
LOL Any one tried I-10 in Louisiana? You can hardly have a conversation in the truck. Your voice sounds like you are talking into a fan. Like one of those annoying things I did as a kid.
Florida roads are not great, but we appreciate them after returning from our bumpy trips.
2014 35 V-Lite 30WIKSS Platinum
Expedition 5.4, Hankook, Reese 1200 Round Bar, Trans-Go, Hadden, Curt Tri-Flex, 3.73 Posi-Traction
Ree is offline   Reply With Quote
Old 09-28-2018, 01:27 PM   #9
World Wide Wanderer
wahoonc's Avatar
Part of the problem is the suspension they use in most travel trailers. It isn't the softest riding one out there. IMHO you can't beat a torsion axle for a smooth ride, even on crappy roads. However they cost more.
I had an Airstream, which has torsion axles, and left a partial cup of coffee sitting on the table one morning and rolled out. It was still there where I left it when we stopped for lunch. And the roads that day were not particularly smooth.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is online now   Reply With Quote
Old 09-28-2018, 01:36 PM   #10
rlh1957's Avatar
Small earthquake going on.
I put a go pro camera back there and had it solid mounted in a camera gimbal like shock mount.
I wanted to see how it was on different roads.
Started a stopwatch upfront to time out the roads to know where I would have been.
After seeing it I decided NO I don't want to ride back there for a nap (illegal in most states). It was amazing how things move around even on smooth roads. On a rough road, I think some sailors might get sick.
I can see now anything could get loosened over time. Now I realize not just things I have added, but every screw, hinge, glue joints, mountings are all subject to the same constant and sometimes violent movement and vibrations.
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
rlh1957 is offline   Reply With Quote
