Old 10-09-2016, 03:15 PM   #11
What are you cooking? If you had something like a Dutch Oven, you can slow cook on a regular stove and as suggested bring it to the party. If it is cast iron, it will hold the heat it for a long period of time. The enameled version makes life easy.
Staub Essential Oven, 3.75qt.
Now: $149.96 at surlatable
(cast iron covered with enamel)
Philos3 is offline   Reply With Quote
Old 10-09-2016, 03:47 PM   #12
SunSeeker 3050's Avatar
We have the same rig, year earlier. DW suggests use the propane grill (ours came with rig) unless the weather is against you. Great rigs, enjoy.
SunSeeker 3050 is offline   Reply With Quote
Old 10-09-2016, 04:20 PM   #13
[QUOTE=GreenImp;1337046]Your crockpot will draw over 23 amps at 12v DC (the 2.25 amp rating is for 110V AC). I don't think there are any cigarette lighter circuits that can handle that much current...you will blow the fuse protecting the circuit.[/QUOTEfr
From time to time I run a 400 watt inverter off the f250 cigarette lighter with no problems. Still, not sure I would run 6 hours on the truck or the two golf cart batteries in our coach.
Tom48 is online now   Reply With Quote
Old 10-09-2016, 04:22 PM   #14
NMWildcat's Avatar
Run your generator. Haven't been to a tailgate yet where most everyone wasn't running a genny. But then again, I would cook all I could before hand. 6 hours is a long time
Scott and Liz - Southern NM
Old 10-09-2016, 04:29 PM   #15
Poor mans crockpot!
Originally Posted by jjlavin View Post
In 2 weekends, we are doing a tailgate and I would prefer not to use the generator out of consideration of the people around us. My goal is to get the Crock-Pot cooking for 6ish hours off the batteries - I would use an inverter off the cigarette lighter adapter. I just checking the power that my Crock-Pot consumes. 2.25 amps, 278 watts.
My question - will my RV batteries be able to sustain that kind of power for 6 hours? I have a 2015 Sunseeker 3010ds with the factory batteries.
We have had great luck with getting the crockpot hot at home, wrapping the inner pot with towels, so that it is a tight fit, be sure ALL surfaces are covered, and putting it into a good cooler and keeping it wrapped up until its time to serve. (We use a 2" thick foam cooler)The oldtimers used to do this with a pile of straw and a wooden box. If you are using a cast iron pot it holds the heat even longer.
AFDON is offline   Reply With Quote
Old 10-09-2016, 05:27 PM   #16
GreenImp's Avatar
Send a message via MSN to GreenImp
You can plug a 5000w inverter into a cigarette lighter and not blow the fuse....until you put a load on the other end of the inverter that is. Most modern 12v "Accessory" circuits (aka cigarette lighter plugs) are rated for either 15 or 20 amps at 12v...this equates to a little over 200w at the most. It's not my rule, it's Ohm's law.
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 10-09-2016, 06:18 PM   #17
Cyber Phrenologist
Radio's Avatar
What if you set up a double boiler arrangement in one of those shrimp boil/turkey fryer things?
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 10-09-2016, 07:57 PM   #18
x2
Cast Iron Pot (Dutch Oven type) over propane stove is all you need to use and will work just as well. I guarantee your neighbors will not hear this setup ;-)
Skyliner is offline   Reply With Quote
Old 10-09-2016, 08:54 PM   #19
Ree
Originally Posted by Ford Idaho View Post
I'd cook it at home and then warm it up at the party
Less work there, less drawdown on your battery = win-win.
X2
2014 35 V-Lite 30WIKSS Platinum
Expedition 5.4, Hankook, Reese 1200 Round Bar, Trans-Go, Hadden, Curt Tri-Flex, 3.73 Posi-Traction
Ree is offline   Reply With Quote
Old 10-09-2016, 09:14 PM   #20
[QUOTE=Tom48;1337186]
You may be "running a 400 watt inverter" but are you powering something that's actually using 400 watts? I suspect you're not. 400 watts would be 33 amps at 12 VDC. Most cigarette lighters have 20 amp fuses. So I'm guessing that whatever you've actually got plugged into your 400 watt inverter is actually using something less than 240 watts.
1988 Coleman Sequoia - popup (1987-2009)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
