Old 10-09-2016, 08:20 PM   #21
NMWildcat's Avatar
I can tell you from experience that a 400watt inverter did NOT run any of the crock pots we tried it with, even on low settings. It would pop the overload protection on the inverter within a few seconds.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 10-09-2016, 08:32 PM   #22
Most inverters that dare claim 400 watts do not do this with a cigarette lighter connection. You will find a pair of big alligator clips in the box as well. Cigarette lighters are not capable of the required amperage.
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 10-09-2016, 10:01 PM   #23
Tom48's Avatar
You may well be correct. The largest thing I have run from the cigarette lighter with my 400 watt modified sine wave inverter is a 2.4 amp load.
I guess that's about 288 Watts but I also run a DirecTV box on my cigarette lighter inverter all the time without a problem.
I run my 2001 pure sine wave directly from the batteries with the 3-foot 2 gauge cables. And, if I was planning to run at higher wattage for any length of time I would rewire it with 2-0 cable but before I would run heavy loads for any length of time I would have to install two more golf cart batteries.
Tom48
Tom48 is offline   Reply With Quote
Old 10-10-2016, 11:43 AM   #24
Tom48
I think you dropped a decimal. 2.4 amps x 12 volts = 28.8 watts.
2011 Traverse LT, 3.6L, FWD
Old 10-10-2016, 12:41 PM   #25
Not on the ac side. That is about 288 watts at 117 volts
2015 335DS
Old 10-10-2016, 01:17 PM   #26
Rockfordroo,
The watts don't change on DC the amps do. Multiply amps by 10.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 10-10-2016, 02:34 PM   #27
I was assuming he meant 2.4 amps at 12V, since those were the amps we were discussing. He wasn't very clear.
Old 10-13-2016, 12:59 AM   #28
Rkloud9's Avatar
We tried running a small crockpot with a 200 watt msw inverter while underway... the vintage small round crockpot we have fits in our round sink, and we used the cigarette lighter connection from the "over the door" tech cabinet on our 2017 SunSeeker MBS 2400 W. Only the low setting was possible... on high the inverter "tripped out". The crockpot is rated at 400 watts for full power, no rating for low.
I noticed there was one open 12 volt circuit in our power panel, so we got a 500 watt msw inverter, and I installed it on that circuit with a 30 amp fuse. I have read elsewhere the these appliance watt ratings are often overstated, so my hope was that the actual crockpot draw on high would be less. The new inverter has a readout for the load it is supplying in watts, along with the battery supply voltage... we lucked out, with the load on the high setting reading 270 watts. While underway, with the engine charging the batteries, this slow cooker set-up works great. When we stop, we can watch the batteries die, with the charge getting down to 12.1 volts in maybe 1/2 hour to 45 minutes... I have been keeping those stock batteries watered and charged, but I do not think the 2 of them can produce anywhere close to the 80 amp hours they should before dropping below the safe 50% discharge.
I know this does not directly answer your Tailgating question, other than to back up what others are saying about your need for a more robust battery bank to even get started with the slow cooker. My slow cooker is pretty small, an at the high setting 4 hours of operation would use about 100 amp hours, plus the at least 20% efficiency drop inherent with inverters.
Let us know what you end up doing.
Bob & Cynthia
2017 SunSeeker MBS 2400W
Bob & Cynthia
Rkloud9 is offline   Reply With Quote
Old 10-13-2016, 05:21 AM   #29
JohnF's Avatar
Cast iron on propane stove.
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
JohnF is offline   Reply With Quote
Old 10-13-2016, 05:50 AM   #30
Mainframe's Avatar
I have often wondered if installing this https://www.tesla.com/powerwall in a motorhome would be an option, it would seem useful ln a tailgate or race track setting where the generator noise might be prohibited. I wonder how long it could run the rooftop a/c for the night etc.I also wonder if they could bounce down the road and stay in tact LOL.
I know if I was a race fan or other event type motorhome user I would be looking into it.
2016 Shamrock 23WS
Mainframe is online now   Reply With Quote
