Old 10-09-2016, 11:55 AM   #1
Running Crock-Pot on the batteries
In 2 weekends, we are doing a tailgate and I would prefer not to use the generator out of consideration of the people around us. My goal is to get the Crock-Pot cooking for 6ish hours off the batteries - I would use an inverter off the cigarette lighter adapter. I just checking the power that my Crock-Pot consumes. 2.25 amps, 278 watts.
My question - will my RV batteries be able to sustain that kind of power for 6 hours? I have a 2015 Sunseeker 3010ds with the factory batteries.
jjlavin is offline   Reply With Quote
Old 10-09-2016, 12:00 PM   #2
Ford Idaho's Avatar
I'd cook it at home and then warm it up at the party
Less work there, less drawdown on your battery = win-win.
Ford Idaho is online now   Reply With Quote
Old 10-09-2016, 12:00 PM   #3
Cigarette outlet,Very Bad idea! Run Genny,or Cook before and heat in Oven! Youroo!!
Old 10-09-2016, 12:47 PM   #4
GreenImp's Avatar
Send a message via MSN to GreenImp
Your crockpot will draw over 23 amps at 12v DC (the 2.25 amp rating is for 110V AC). I don't think there are any cigarette lighter circuits that can handle that much current...you will blow the fuse protecting the circuit.
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 10-09-2016, 12:51 PM   #5
2012 Solera
278 Watts at 12 volts - about 25 amps (with inverter losses). Unless you have a huge battery bank, you will kill your batteries in short order.
12 volt amps are over 10 times 120 volt amps, FYI.
JLeising
2012 Solera "S"
Calif SF Bay Area
JLeising is online now   Reply With Quote
Old 10-09-2016, 12:57 PM   #6
Flybob's Avatar
With losses in the inverter, you will be drawing over 25 amps from your battery / lighter outlet for six hours. I will most likely either blow the fuse or melt the lighter outlet/plug. In addition that is 150AHr which is is way more than most standard battery set ups can support. Cook at home then heat up on propane stove .
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 10-09-2016, 12:59 PM   #7
GreenImp's Avatar
Even if you bypassed the 12v socket circuit (wired directly or whatever), you would need a minimum of a little over 400Ah battery capacity for this one task alone.
In simpler terms, your looking at about 4 6v golf cart batteries to safely handle that single task.
Old 10-09-2016, 01:32 PM   #8
Boso's Avatar
Crock pot
Simple answer is no
Boso is offline   Reply With Quote
Old 10-09-2016, 03:02 PM   #9
Have you thought of getting a 12 Volt slow cooker? Amazon shows quite a few different models.
mbutts is offline   Reply With Quote
Old 10-09-2016, 03:14 PM   #10
Flybob's Avatar
An crock pot with equivalent capability will still require just under 300W or about 22A so you will have same problem with a 12V version.
TST Tire Monitors
2 65W solar panels
