02-25-2016, 11:41 AM
Running RV A/C on the road?
When we are traveling, the back of the rv gets pretty hot and our kids complain about it. I haven't figured out how to run the A/C unit without running the generator. I was speaking to a Class A owner and he mentioned he was doing the same until he discovered the electric inverter and was able to switch the electric from going to the batteries to the A/C unit. Can I do what he mentioned?
Kristina
2016 Rockwood Premier 2317G
2021 F150 XLT
Previously:
2005 Fleetwood Seapine, 2012 Rockwood Roo
2015 Sunseeker, 2017 Fleetwood Pace Arrow
02-25-2016, 11:45 AM
Berkshire 390QS
Don't think you can run the roof ac without having the generator on. AC takes alot of power to run and the batteries won't do it.
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
2019: 156 days (2009 Berkshire, 390QS, and toad)
02-25-2016, 12:11 PM
It is possible, but it would require an inverter of at least 2000 watts capacity and dual alternators of at least 250 amps total capacity. Unless you already have that installed, running a generator makes more sense.
02-25-2016, 12:15 PM
Thanks for the info. 😊
Kristina
2021 F150 XLT
Previously:
02-25-2016, 01:31 PM
I've been told that you will use less gas running the Genny and air than running dash air and of course making the engine work harder
I run the dash cause it's just the two of us but start the Genny on the last leg of the trip (hour or so) to precool at set up
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
02-25-2016, 02:17 PM
geezer with gadgets
Hockeytownmom, we have the same model MH and we run the generator when we need the AC on in the unit. We traveled over 7,000 miles last summer and ran it most of the time while driving. No problems, didn't really see much difference in the gas consumption with or without the generator running.
When we first joined the forum last year that was a big question for me as well and many responses were to run the generator, "that's what it is there for."
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 57 2019: 30
02-26-2016, 01:56 PM
I concur, when we travel the genset is running
2014 Forest River Sunseeker 3170DS
TOAD: 2016 Jeep Wrangler Unlimited - Black Bear Edition
02-26-2016, 03:29 PM
We run the generator and a/c too on hot days to keep the dog cool!
Phil, Heather & Olaf the Boxer
Ontario Canada
Lexington 283GTS
02-26-2016, 03:56 PM
It's not a problem to run the generator so you can have your ac on while traveling. I have owned two diesel pushers and neither one was wired to the inverter. Honestly I don't believe they do that, but who knows. You cannot do that on a Sunseeker for sure it doesn't have a inverter at all.
2015 sunseeker 3050s. 2007 saturn aura
02-27-2016, 08:45 AM
Driving & using the generator,,,
Sure seams to me that would drain the fuel tank PDQ ???
02-27-2016, 08:51 AM
Yeah, at about a gallon an hour fully loaded shouldn't take long to empty that gas tank..
02-27-2016, 08:55 AM
Genny is made to run. Actually works better when it's run regularly. We use it whenever we need it.
02-27-2016, 09:21 AM
World Wide Wanderer
My generator is rated at .5 gallon per hour at half load. Unless it is blistering hot I doubt you would exceed that with the A/C on. FWIW by my calculations that would take me from 8.5 mpg down to maybe 7.9 mpg. Small price to pay for being comfortable. If you want to run the A/C off an inverter it is going to take a big one, big battery bank and big alternator to keep up. Not cheap to install. On some buses I have seen basement air that is run off the engine compressor, and then has a second compressor that can be run off electricity when parked. Again, not an inexpensive installation.
Aaron
02-27-2016, 10:04 AM
Not really I think mine will run an hour on a gallon of gas. So it wouldn't have that much of an effect on gas mileage.
02-27-2016, 10:05 AM
We run ours an hour a month whether we use it or not.
02-27-2016, 10:10 AM
Not to bad @ todays gas prices,,,
But not so good back when we were paying $4 a gallon !!!
