Old 02-25-2016, 01:12 PM   #11
geezer with gadgets
757Dave's Avatar
Originally Posted by JLeising View Post
Most of the discussions involve the wide use of the CH751 key. This is a small, single sided key. The compartments on our Solera use a double sided key - nothing like a CH751. Doubt your Sunseeker compartments use a 751 key.
Our Sunseeker had the 751 key on all outside storage and shower. We used the same distributor that Scubanut used and replaced them easily.
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 48
757Dave is offline   Reply With Quote
Old 02-25-2016, 02:42 PM   #12
jgump's Avatar
I replaced my 751's with barrel style locks. Mine were 7/8 on a forest river wildwood TT. Piece of cake and also really tightened up the door when closed and latched. Yes, if someone wanted in they can find a way but anything to slow them down and also avoid the "what if they just happened to have a 751 with them". Got them on Amazon. I replaced the one thumb turn latch with these as well so double locks on each baggage door.
John
2016 Wildwood 27RKSS
2012 Grand Cherokee Overland (Hemi)
jgump is offline   Reply With Quote
Old 02-25-2016, 02:52 PM   #13
Can you remove the key when they are unlocked? Some you have to leave the key in or turn it back to the locked position to get the key out.
Kevin & Judy is offline   Reply With Quote
Old 02-25-2016, 02:56 PM   #14
jgump's Avatar
No you can't. But honestly when I turn the key to unlock I just pull out a little on the key and then relock but the catch on the inside doesn't latch back to the frame. Piece of cake. Piece of mind.
Old 02-25-2016, 05:44 PM   #15
I used ILH also...great service and good locks. They'll also let you key them all alike, or have a couple that are different if you have that need. They'll even color code the keys. But as a someone else may have said, you need to measure every single lock you are replacing. For example, I used three different size configurations on my Sunseeker 3010 DS (2015). Just because they look the same doesn't mean they are.
jeffreymhardy is offline   Reply With Quote
Old 02-25-2016, 09:24 PM   #16
Who Dares, Wins
doc73's Avatar
Changed my locks out this winder to the cam locks. They are much nicer to use and seem much better built than the cheap old locks FR put on. I did the locks a bit for security but mostly because the locks never worked great and the key was always very sloppy when put in the hole. I had a few times were things jammed up and not unlocking... Not anymore!
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 03-09-2016, 08:20 PM   #17
Wa11y757's Avatar
Rv compartment locks
They can be removed if modified
Wa11y757 is offline   Reply With Quote
Old 03-09-2016, 08:22 PM   #18
Left Coast
Look in locked compartment! Lol
Old 03-09-2016, 08:23 PM   #19
Wa11y757's Avatar
I filed the little tab off the cam lock keys so I could remove the key while it is unlocked and do the next lock. I also put 2 locks on each door.
Now I'm going back to looking for my 10mm wrench! 2016 Wildwood 27RKSS
2005 F250 PSD
Old 03-09-2016, 08:27 PM   #20
Left Coast
Wally757....My post was to follow yours..lol
lock
