Old 09-03-2016, 08:44 AM   #11
Dump all your air out of the air bags and re measure .if you are still off by two inches side to side and not overloaded on one side or the other you either have suspension problems or a bent or twisted frame
lbrunning is offline   Reply With Quote
Old 09-03-2016, 05:09 PM   #12
we got to an inch with 70 lb in the passenger side bag, and 40 lb in the drivers side. we will keep an eye on it.
castaway is offline   Reply With Quote
Old 09-07-2016, 07:58 PM   #13
Our 2015 2700 sits lower on the passenger site as well.
I've never measured the difference side to side.
Both air bags have the exact same pressure. I haven't tried airing up one side.
jst3 is offline   Reply With Quote
Old 09-07-2016, 09:12 PM   #14
Ok ppl. We have a 2012 3100ss and this is our first MH we got in Apr 2015. I'm reading the post about passenger side being a little lower. We did not get any owners manual and what FR sent us is VERY generic. Do we have airbags that I don't know about?
aemail4sue is offline   Reply With Quote
Old 09-07-2016, 11:16 PM   #15
Beards79's Avatar
To my knowledge sunseeker puts air bags standard on all their class c motorhomes, I have a 2300 and inside the storage compartment on each side of the coach (compartments nearest to the rear wheels on mine) there is a valve stem just like you would find on a tire mounted on the inside of the compartment about 1/2 way up on the wall. These are to air up the air bags if you have them.
Take Vacations.. Go as many places as you can!
You can always make money..
But you can't always make memories!
Beards79 is online now   Reply With Quote
Old 11-20-2016, 06:45 PM   #16
Our 2300 Chevy sits an inch lower on the passenger side, measured at the rear bumper.
As to the height adjustment range with air bags, I found that with the coach empty, the air bags raise the bumper about one inch at any psi setting over 10 or 20. In other words, it doesn't matter if I put 20 or 100, as far as ride height. It might be different with a big load on board.
2014 Sunseeker 2300 Chevy
Snowman9000 is offline   Reply With Quote
