Old 02-27-2013, 08:45 PM   #1
osgood's Avatar
Rv storage and shore power
I have always had travel trailers in the past. I have always had them plugged in while in the garage. This is my first motorhome so I am a bit paranoid about the care. Will it harm anything to leave my sunseeker always plugged in. I am assuming ill want to unplug it before running the engine and before I exercise the generator?
osgood is offline   Reply With Quote
Old 02-27-2013, 09:43 PM   #2
I always open the battery disconnect switch and put Detran battery tenders on both coach and chassis batteries when in the garage. However I believe the converters used in the Sunseeker are three stage untis so you should be able to leave them plugged in all the time. I just think why keep all the electronics (converter, LP detector, microwave, tvs, etc) energized when not needed.
ATVer is offline   Reply With Quote
Old 02-27-2013, 09:48 PM   #3
osgood's Avatar
I use our unit at least once a month. I usually leave the fridge on all the time. This is close to my office so when I want to get away for peace and quiet to work I go to the camper.
I could think of a lot worse places to work.
Old 03-01-2013, 12:53 PM   #4
Plain Old Member
Ours have always been on shore power while parked in the garage, genset while running from the day we bought them to the day we sold them. Never a problem. I haven't researched this converter yet. Hope it is the 3 stage. Had to upgrade the intellipower converter with the charge wizard on previous trailers.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 03-02-2013, 10:09 AM   #5
RudysWorld's Avatar
I have a MH and keep plugged in all the time. I keep it at home and it is convenient if I want to check anything in the MH or open slides. I disconnect house batteries when plugged in because I had a over charge problem with the batteries.
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
RudysWorld is offline   Reply With Quote
Old 03-02-2013, 06:15 PM   #6
It may be over kill from our old motor home, but we leave the batteries disconnected most of the time; but once a month run the shore power for a few days then run the RV and the generator for an hour loaded by a space heater. It seems to keep the batteries happy, but again, may be overkill
Geri is offline   Reply With Quote
