Old 03-12-2016, 05:19 AM   #1
RV Vent Fan on Batteries
How long can I leave my RV vent fan on at medium speed (#2) before my battery drains to 50%? I am safe to leave the fan on for 6 hours?
I have a 2015 Sunseeker 2300, everything is off except for the standard lights from the chagrin ports, Entertainment console and tv LED light. The fridge is running on LP.
Thank you
Airbornemp is offline   Reply With Quote
Old 03-12-2016, 05:24 AM   #2
deebarjay's Avatar
The battery is running on LP........what does that mean??
2008 F250 6.4 diesel with 50 gal aux tank towing a 2015 Rockwood 2109s Minilite.
2015 Miles and nights
10040/31
2016 miles and nights
feb. 380/7......march 540/3
deebarjay is offline   Reply With Quote
Old 03-12-2016, 05:25 AM   #3
I meant the fridge is running on LP has.
Old 03-12-2016, 10:34 AM   #4
2012 Solera
From a Google search, appears Fantastic Fan draws about 2.3 amps on mid-speed, 3 amps on high speed. Six hours would drain batteries about 15 amp-hours.
On our Solera with the factory installed dual size 27 batteries (about 200 amp hours total capacity) I have run the Fantastic Fan (with the fridge on propane ) that long a few times without a problem.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 03-12-2016, 12:45 PM   #5
I have a 2013 Sunseeker 2300 and have run the vent fan on low setting overnight with no problems. Now have a dual Interstate size 27 setup and don't give it a thought. I've upgraded all 3 vents to 3 stage Fantastic Fans and commonly use one "inflow" in the front an one "outflow" in the rear, sometimes reversed, overnight without a problem.
FYI. Factory batteries are junk. Maybe because made that way, maybe because of sitting unused at the factory/dealer. Doesn't matter which. They have a very short life!
RubberNail is offline   Reply With Quote
Old 03-12-2016, 12:55 PM   #6
Flybob's Avatar
Thank you
Fridge on ( either mode) means control board drawing 12V current, CO.Propane detector on also.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-12-2016, 12:58 PM   #7
Don't forget that even though you have the refrig operating on propane, it still is using a small amount 12v to run the refrig controls.
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
Old 03-12-2016, 06:14 PM   #8
Fan
I leave my FF running all day to vent the trailer. Never had a problem with a single 27 DEEP CYCLE battery. Last year I added a flexible 100 watt solar panel to the top of my 21DS, ran the cables down the awning support, into the storage compartment, then out to a 10 amp controller and to the battery. I have absolutely no power worries now! Works year round. Just top off the water before your first trip of the season and periodically during.
randman132 is offline   Reply With Quote
Old 03-12-2016, 07:32 PM   #9
I have to ask?
What do a battery and Propane have to do with one another?
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
silverback 35ts is offline   Reply With Quote
Old 03-12-2016, 07:35 PM   #10
Since you cleared that up?
You should be able to run most any rv fridge for 8 hrs on your battery (if it is charged and in good shape when you start)
B.Smith
fan, vent, battery
