Old 02-08-2018, 07:34 AM   #1
2014 SunSeeker 2300
Awilson's Avatar
RVS Multiplexer
I have a SunSeeker 2300 that has the RVS-770619NA camera system that has given me problems off and on and I asked for help on here last year. I got the help I needed in finding it. The problem is the camera on the right side does not always come on so I can see when itís safe to pull back over. It works very sporadically by coming on like 10 times in a row then not working for 50! Frustrating! I have taken the unit out from under dash, reconnected all the wires, did a hard reset by disconnecting the power as instructed by the factory and when I got finished I checked for a signal and it is just as good as the left side.
I am hoping someone has run into this problem and found a solution cause Iím at my wits end. I have talked to the factory multiple times and keep getting the same answer, no signal. What to do?
. We are now retired and living the dream! 2014 2300 SunSeeker without slides that we remodeled inside for better living conditions for two people.
Awilson is offline   Reply With Quote
Old 02-08-2018, 11:17 AM   #2
Kirk S's Avatar
I would try, for test purposes only, swapping the camera inputs. If it still happens when the right turn signal is activated I would rule out the camera and suspect the trigger signal or just a defective multiplexer. If the problem switches sides I would suspect the camera not providing a consistent signal.
I have a different, aftermarket, 2 input system on a pick-up truck that will not switch inputs if no signal from one of the cameras due to loss of power at the camera.
Good luck!
Kirk
2017 Forester 3051S
Kirk S is online now   Reply With Quote
Old 02-08-2018, 01:08 PM   #3
2014 SunSeeker 2300
Awilson's Avatar
Thanks for the input. I will try that in the near future when I get stopped.
